Hi! I've been uploading multibeam and singlebeam data (some sorted, some not) to my BIS. Some datasets are being rendered with "blocks." I have attached images to illustrate.
Example 1: This is a sorted multibeam dataset. The not so dense "dots" bound in blue are what I expected the data to be, but some areas are more generalized, it seems, such as the one bound in green. Again, the sorting throughout the dataset is the same, so it should only be either dense dots or generalized, and not both.
Example 2: This is also a sorted multibeam dataset. The same problem as in Example 1 exists.
Example 3: This is an unsorted singlebeam dataset. The same problems as in Examples 1 and 2 subsists.
I have uploaded these datasets repeatedly thinking that it was a BIS-upload problem but it was not. However, I have been successful in my other dataset uploads, both multibeam and singlebeam:
Is this a mosaicking problem or something to do with my PC (NVIDIDA Quadro RTX 4000 graphics card and intel i9 with 256 RAM)? Your help with this is much appreciated!
