FAA FAR 77 tool warning: “Airport reference point and runway end points are significantly different” with validated geometry
993
6
02-15-2026 08:10 PM
CarieErnst_KYTC
I am running the FAA FAR 77 tool in ArcGIS Pro (version 3.5) and consistently receive the warning:
“The airport reference point and the runway end points are significantly different. This may cause the obstruction identification surfaces to generate incorrectly.”
However, I have validated the geometry and cannot identify any spatial inconsistency:
  • Single runway airport
  • Runway length: 3849.97 ft
  • ARP to Runway End A: 1924.70 ft
  • ARP to Runway End B: 1925.27 ft
  • Difference from midpoint: ~0.57 ft
  • Data projected to WKID 3089 (Kentucky Single Zone, US Feet) Vertical WKID 6360
  • Map coordinate system matches dataset
  • No displaced thresholds
  • Only one runway feature
  • Runway centerline is a simple 2-vertex line
  • Airport elevation parameter correctly supplied (1040 ft)
  • Runway end elevations are consistent
  • No joins or definition queries
  • All features exported into a clean file geodatabase
The generated OIS surfaces appear correct and centered.
Given the above, I am trying to determine:
  1. What tolerance threshold triggers this warning?
  2. Is the check purely horizontal, or does it include vertical comparison?
  3. Is this known to occur due to internal reprojection or rounding?
  4. Can this warning safely be ignored when geometry is validated?
Any insight into the internal validation logic would be appreciated.
Thank you.
Sara_Courter
I have already responded to your email, but I wanted to post this answer for the community to see.
I have read through your parameters, and below is a response to your questions.
    The tolerance is 150ft. The reason the tolerance is 150ft is that if the horizontal surface is too high or too low, it will not intersect the approach surface and hence fail to generate transitional surfaces. However, I see this warning all the time when I run the tool with the COS data. However, I do see there is a 900ft difference between your ARP and the Runway Ends, is this correct?
    It's mostly focusing on the Horizontal and Conical surfaces. The primary, approach, and transitional are based on the elevation of the runway ends.
    No, as stated above, this is just so the user is aware and has the opportunity to double-check the geometry.
    Yes, if you have checked your geometry of the multipatches and everything looks good, you can safely ignore the message.
Additionally, we have made enhancements to the FAR 77 tool. If you haven't already, please feel free to check out this brief tutorial on Creating Part-77 Surfaces.
Best,
Sara
KiyoshiYamashita
Hi! Apologies for answering your question with a question... but do your Airport Reference Point and Runway End features all have z-values?
Usually, this warning is triggered when the airfield elevation (which can come from the ARP feature) and the runway end elevation (which can come from the Runway End features) are very different.  Since some of the part 77 surfaces are constructed relative to these different elevations, if they are drastically different, the tool can have trouble making sure all the surfaces connect appropriately.
If you are able to share your input data, I can tell you more specifically why you received that warning.  You can attach a zipped GDB here or send to [email protected] (attn: Kiyoshi Y) if unable to share publicly.
CarieErnst_KYTC
Hi Kiyoshi,
Yes, the ARP does have z values. I will send you a FGDB and appreciate any insight you can provide.
Jaimie_Nevins
@CarieErnst_KYTC  did you get a response and a solution to this error?  I am experiencing the same thing when I run my part 77 tool...but only for a few airports.  The data formats are exactly the same, and resulting surface layers look correct (just like your results).  So I'm curious if this is a bug or an actual problem.  Thanks!
KYTCGIS
Hi Jamie, I'm just now circling back and realizing I had responses. I did not find a solution but intend to reach out to Kiyoshi and will let you know if we uncover anything. Did you find a solution yet?
Sara_Courter
Best,
Sara
KiyoshiYamashita
Hi @CarieErnst_KYTC & @KYTCGIS - just piggybacking on Sara's response to add some more specifics based on the data that you shared.
For the specific airport you described, I found the ARP and Runway End points in the data you sent.  The ARP has an elevation (and corresponding z-coordinate) of 1040 ft.  However, the runway end points have an elevation and z-coordinate of 0 ft (see images below).  This huge gap is what the warning message is describing.
To address the warning, ensure that the z-coordinate of the runway ends (specifically the vertices on the RunwayCenterline feature) is updated to the appropriate elevation.  You can fix this manually using the Edit Vertices tool on the Edit ribbon.
As Sara mentioned, the warning is triggered when the vertical difference between the airfield elevation and the runway ends is more than 150 ft.  This is because the horizontal and conical surfaces are built relative to the airfield elevation (150 ft above), while the other surfaces are built relative to the runway ends' elevations.  If the difference is too great, it can cause issues with the transitional surfaces.
