Hello,
I am running the FAA FAR 77 tool in ArcGIS Pro (version 3.5) and consistently receive the warning:
“The airport reference point and the runway end points are significantly different. This may cause the obstruction identification surfaces to generate incorrectly.”
However, I have validated the geometry and cannot identify any spatial inconsistency:
Single runway airport
Runway length: 3849.97 ft
ARP to Runway End A: 1924.70 ft
ARP to Runway End B: 1925.27 ft
Difference from midpoint: ~0.57 ft
Data projected to WKID 3089 (Kentucky Single Zone, US Feet) Vertical WKID 6360
Map coordinate system matches dataset
No displaced thresholds
Only one runway feature
Runway centerline is a simple 2-vertex line
Airport elevation parameter correctly supplied (1040 ft)
Runway end elevations are consistent
No joins or definition queries
All features exported into a clean file geodatabase
The generated OIS surfaces appear correct and centered.
Given the above, I am trying to determine:
What tolerance threshold triggers this warning?
Is the check purely horizontal, or does it include vertical comparison?
Is this known to occur due to internal reprojection or rounding?
Can this warning safely be ignored when geometry is validated?
Any insight into the internal validation logic would be appreciated.
Thank you.
Solved! Go to Solution.
Hi @CarieErnst_KYTC & @KYTCGIS - just piggybacking on Sara's response to add some more specifics based on the data that you shared.
For the specific airport you described, I found the ARP and Runway End points in the data you sent. The ARP has an elevation (and corresponding z-coordinate) of 1040 ft. However, the runway end points have an elevation and z-coordinate of 0 ft (see images below). This huge gap is what the warning message is describing.
To address the warning, ensure that the z-coordinate of the runway ends (specifically the vertices on the RunwayCenterline feature) is updated to the appropriate elevation. You can fix this manually using the Edit Vertices tool on the Edit ribbon.
As Sara mentioned, the warning is triggered when the vertical difference between the airfield elevation and the runway ends is more than 150 ft. This is because the horizontal and conical surfaces are built relative to the airfield elevation (150 ft above), while the other surfaces are built relative to the runway ends' elevations. If the difference is too great, it can cause issues with the transitional surfaces.
Hi! Apologies for answering your question with a question... but do your Airport Reference Point and Runway End features all have z-values?
Usually, this warning is triggered when the airfield elevation (which can come from the ARP feature) and the runway end elevation (which can come from the Runway End features) are very different. Since some of the part 77 surfaces are constructed relative to these different elevations, if they are drastically different, the tool can have trouble making sure all the surfaces connect appropriately.
If you are able to share your input data, I can tell you more specifically why you received that warning. You can attach a zipped GDB here or send to [email protected] (attn: Kiyoshi Y) if unable to share publicly.
Hi Kiyoshi,
Yes, the ARP does have z values. I will send you a FGDB and appreciate any insight you can provide.
@CarieErnst_KYTC did you get a response and a solution to this error? I am experiencing the same thing when I run my part 77 tool...but only for a few airports. The data formats are exactly the same, and resulting surface layers look correct (just like your results). So I'm curious if this is a bug or an actual problem. Thanks!
Hi Jamie, I'm just now circling back and realizing I had responses. I did not find a solution but intend to reach out to Kiyoshi and will let you know if we uncover anything. Did you find a solution yet?
