Set parameter in AndroidManifest.xml or info.plist, cloud compiler
1877
03-12-2019 04:49 AM
MassimilianoSantini
I'm developing an app with AppStudio and QT Creator.
There's a way to insert parameters in Android Manifest file and/or  in iOS info.plist using only the cloud compiler? No local compiler.
I'd like to insert something like android:allowBackup=false in manifest file or NSAllowsArbitraryLoads=YES in info.plist
Thanks
Massimiliano
ShobanaSuresh
Hi Massimiliano,
Currently, it's not possible to insert parameters directly in Android Manifest or iOS info.plist when using Cloud Make.
However, we've made it possible to configure a lot of these properties using appinfo.json.
To insert android:allowBackup=false in Android manifest file, set capabilities.backup to false in appinfo.json
To set NSAllowsArbitraryLoads=YES in iOS info.plist, set
capabilities.ios.appTransportSecurity.allowArbitraryLoads to true in appinfo.json
Manually edit your app's appinfo.json and set below properties. Save the changes, upload the app to ArcGIS Online and submit a Cloud Make build request. Built Android apk will have android:allowBackup=false set in Manifest and iOS ipa will have NSAllowsArbitraryLoads=YES set in info.plist
"capabilities": {
  "backup": false,
  "ios": {
    "appTransportSecurity": {
      "allowArbitraryLoads" : true
Refer Edit appinfo—AppStudio for ArcGIS | ArcGIS  for more details. Above appinfo properties for backup and NSAllowsArbitraryLoads will be added to this documentation soon.
I hope this helps.
Thanks
Shobana
ShobanaSuresh
Hi Massimiliano,
"capabilities": {
  "backup": false,
  "ios": {
I hope this helps.
Thanks
Shobana
