Certificate (.p12) File
3568
05-15-2017 05:19 PM
NathanDaniels
How do I convert an iOS distribution certificate (.cert) to a .p12 file using Windows only? Is this even possible? A Google search indicated that it might be possible using openSSL, however I haven't yet got that method to work. Are you able to point me to any instructions/documentation on how to get the .p12 file using Windows only? Thanks.
StephenQuan1
A .p12 file contains both your iOS Distribution Certificate (.cer) and your private key. They must match. On a Mac this is achieved by importing your .cer into Keychain Access and making sure that your private key is attached to the iOS Distribution Certificate prior to exporting it as a .p12 file.
On Windows, I don't know of a way to do this step, sorry.
However, after you got your .p12 file, you no longer need access a Mac since you can make use of Cloud Make.
StephenQuan1
simoxu
by MVP Alum
MVP Alum
Hi Nathan,
The answer is yes.
If you want to create a p12 file using openSSL on a windows machine, you need to create the CSR file and the Private key using openSSL (I did this on a windows machine, but I guess you don't have to). then you can create a iOS certificate using the CSR on the Apple Developer website.
As Stephen mentioned, once you have the certificate and the corresponding private key, you can create p12 file using openSSL.
KE
These links may help you:
Download and Install OpenSSL - (I used Win64 OpenSSL v1.1.0e Light):
https://slproweb.com/products/Win32OpenSSL.html
Follow these directions:
https://www.joshmorony.com/how-to-create-an-ios-provisioning-profile-and-p12-with-windows/
