Hi Alex,
Do you know that AppStudio 4.0 brought this amazing Select QML Component function into the Qt Creator? This is a similar functionality as in Web Browser Developer tool, where you can inspect HTML components.
Here are the steps of how to use it.
Steps:
1. Open your custom Survey 123 in Qt Creator.
2. Click on the Debugger button on the bottom left corner of the Qt Creator.
3. Go to Debug menu, then make sure to enable "Show Application on Top", then "Select"
4. Now you would be able to select on the QML components in the UI of the app, then the QML code will be highlighted
I hope this will help you.
Tina
