Replacing url from sample to my service url
1553
6
01-17-2011 06:47 AM
JoannaLaroussi
I replicated in the Silverlight an example ArcGIS Dynamic Layer from ArcGIS API for Microsoft Silverlight. It worked fine, but when I tried to change url of sample to url of my map service, it returned me a white page. I tried with a few map services with the same result. My server is running, I can see my map services in preview of ArcCatalog, but I cannot use it in Silverlight. The url I tried to use is http://myservername/ArcGIS/rest/services/mymapservicename/MapServer. I am running Silverlight on the same machine, where ArcGIS Server 10 is installed. Does somebody have any idea how to make it work?
DominiqueBroux
Esri Frequent Contributor
What to you get if you request your map service URL in your browser?
You should get something like : http://services.arcgisonline.com/ArcGIS/rest/services/Demographics/USA_Median_Home_Value/MapServer
DanielWalton
If your services are on a different server than your Silverlight XAP, do you have a crossdomain.xml file at your server's root directory? E.g.:
http://services.arcgisonline.com/crossdomain.xml
JoannaLaroussi
Thank you for your response. I do see something similar like in your example, but still this url does not work inside Silverlight 😞
JoannaLaroussi
Thanks for the answer! I am just starting with Silverlight and I am not sure I understood your answer. At first I am running Silverlight on the same machine, where I have installed ArcGIS server, which makes me think that my Silverlight XAP is on the same server. I tried to add suggested code inside XAML
<UserControl x:Class="simpleMap.MainPage"
    xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
    xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
    xmlns:esri="http://schemas.esri.com/arcgis/client/2009">
    <Grid x:Name="LayoutRoot" Background="White" >
        <esri:Map x:Name="MyMap" >
            <esri:ArcGISDynamicMapServiceLayer ID="MyLayer"
                Url="http://myservername/ArcGIS/rest/myservicename/MapServer" />
        </esri:Map>
        <?xml version="1.0" ?>
        <cross-domain-policy>
            <allow-access-from domain="*" />
            <site-control permitted-cross-domain-policies="all" />
            <allow-http-request-headers-from domain="*" headers="*" />
        </cross-domain-policy>
    </Grid>
</UserControl>
But I am doing something wrong or in the wrong place�?�
JenniferNery
JoannaLaroussi
Thanks! I will try to check everything.
QUOTE=jenniferdnery;69397]You can read this blog to troubleshoot your application: http://blogs.esri.com/Dev/blogs/silverlightwpf/archive/2009/08/24/Troubleshooting-blank-layers.aspx
This might help you get started too: http://help.arcgis.com/en/webapi/silverlight/help/index.html#/Getting_Started/016600000004000000/
