OverviewMap MaximumExtent Property
1485
07-21-2011 04:04 AM
LanceCrumbliss
Hell all,
I cannot get the MaximumExtent property to honor the MaximumExtent.  The OverviewMap will be static (desired) but instead of the extent defined by the MaximumExtent property, the extent is the full extent of the ArcGISTiledMapServiceLayer used as a source.
            <esri:OverviewMap x:Name="MyOverviewMap" Width="130" Height="130" Map="{Binding ElementName=MyMap}" IsStatic="True" MaximumExtent="3005535,596476,3070530,644436" >
                <esri:OverviewMap.Layer>
                    <esri:ArcGISTiledMapServiceLayer ID="OverViewMap" Url="<ServerAddress>"/>
                </esri:OverviewMap.Layer>
            </esri:OverviewMap>
LanceCrumbliss
Specifically chiming in for comments or suggestions from ESRI guys and gals morten, dominique, or jennifer.  Of course, anyone else that may have a suggestion or comment is welcome to reply as well 🙂
FYI, the overview map and the main map are using the same Tiled Map Service.
DominiqueBroux
Esri Frequent Contributor
Looks like a bug.
We'll try to get it fixed ASAP.
The workaround can be to initialize the IsStatic property after the 2 maps have been initialized.
I get it working with this code:
public OverviewMap(){
InitializeComponent();
MyMap.Layers.LayersInitialized += SetIsStatic;
void SetIsStatic(object sender, System.EventArgs args)
Dispatcher.BeginInvoke(() =>    {
    MyOverviewMap.IsStatic = false;
    MyOverviewMap.IsStatic = true;
And in XAML:
<esri:ArcGISTiledMapServiceLayer ID="StreetLayer"  Initialized="SetIsStatic"
   Url="http://services.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer"/>
Thanks for reporting that.
LanceCrumbliss
Great workaround. 😄 Thanks Dominique.
