Export map image
1507
07-12-2011 10:32 PM
OndrejRenner
I would like to export a map to the png file. But the resulting file is empty. This is my solution:
In MainPage is (piece of code)
<Border x:Name="mapBorder" Background="White" CornerRadius="5" BorderThickness="1" BorderBrush="Black" Margin="5" Grid.Column="0">
<Grid>
<esri:Map x:Name="MyMap" Margin="5" >
<esri:ArcGISDynamicMapServiceLayer ID="BackMap" Url="http://w2003gis/ArcGIS/rest/services/BackMap/MapServer" />
<esri:ArcGISDynamicMapServiceLayer ID="DynamicMap" Url="http://w2003gis/ArcGIS/rest/services/HrAdminDiv/MapServer" />
<esri:GraphicsLayer ID="SingleAnalysisGraphicsLayer" />
<esri:GraphicsLayer ID="MultiAnalysisGraphicsLayer" />
</esri:Map>
</Grid>
</Border>
(GraphicsLayers are filled in code behind)
And in code i do this:
var sfd = new SaveFileDialog();
sfd.Filter = "PNG Image File (*.png)|*.png";
WriteableBitmap wbmp = (MyMap, new TranslateTransform());
if (sfd.ShowDialog() == true)
    using (Stream stream = sfd.OpenFile())
        var enc = new PngEncoder();
        enc.Encode(wbmp.ToImage(), stream);
        stream.Close();
Result file is empty (size is 0).
When I export only GrapgicsLayer, everything is OK, but I miss the BackMap and DynamicMap layer.
WriteableBitmap wbmp = ((ArcGISDynamicMapServiceLayer)MyMap.Layers["BackMap"]).ToBitmap();
        stream.Close();
How can I export every layers from MyMap object to graphic file?
Thanks, O.
JenniferNery
OndrejRenner
When I use Layer.ToBitmap() on the graphics layer (which is on the client side), everything is fine. But when I use the Layer.ToBitmap on ArcGISDynamicMapServiceLayer, the resulting image is blank. Finally, I need to export the layer collection and this is same problem - empty image.
O
OndrejRenner
anyone help?
