how do you know the name of the field?
571
12-21-2011 08:53 PM
DidarBultanov
I get the data using the identification
I need to know the name of the field, not alias
 private void Search_Num(object sender, IdentifyEventArgs args)
 if (args.IdentifyResults.Count > 0)
result.Feature.Attributes["My_field"] != null
- then returned to no-name field, and the alias
JenniferNery
IdentifyTask use Alias but you can use Linq query to find the Field.Name.
If you are using 2.3 and up, you can use GetDetails/GetAllDetails to get to the FeatureLayerInfo.
GetDet
http://help.arcgis.com/en/webapi/silverlight/apiref/ESRI.ArcGIS.Client~ESRI.ArcGIS.Client.ArcGISDyna...
  l.GetDetails(layerId,
    (a, b) =>
     var field = a.Fields.FirstOrDefault(f => f.Alias == alias);
where l is ArcGISDynamicMapServiceLayer that points to the same MapServer as your IdentifyTask and alias is from IdentifyTask.
