C# alter Identify Task output
2321
12-30-2011 07:22 AM
NigelAlford
"ESRI QUOTE :Each FindResult contains the feature found, the name and ID of the layer containing the feature, the name of the field containing the matching value, and other information."
what would I alter the find result to display the "other information"/columns associated with the identified feature?
Thanks in advance
private void ExecuteButton_Click(object sender, System.Windows.RoutedEventArgs e)
         GraphicsLayer graphicsLayer = MyMap.Layers["Results"] as GraphicsLayer;
            graphicsLayer.ClearGraphics();
            FindTask findTask = new FindTask("http://esoc1d/ArcGISTEST/rest/services/ITGIS/LOCOMOTIVE_LOCATION/MapServer");
            //added to label features on map and show messagebox if query was empty
            //see line:1132
            findTask.ExecuteCompleted += new EventHandler<FindEventArgs>(findTask_ExecuteCompleted);
            findTask.Failed += FindTask_Failed;
            FindParameters findParameters = new FindParameters();
            // Layer ids to search
            findParameters.LayerIds.AddRange(new int[] { 5, 6, 7, 8 });
            // Fields in layers to search
            findParameters.SearchFields.AddRange(new string[] { "LOC_INIT", "LOC_NUM", "DTM", "LOC_TYPE", "FUEL_LEVEL", "ENGINE_ONOFF", "ENGINE_TEMP" });
            // Return features in map's spatial reference
            findParameters.SpatialReference = MyMap.SpatialReference;
             // Bind data grid to find results.  Bind to the LastResult property which returns a list
            // of FindResult instances.  When LastResult is updated, the ItemsSource property on the
            // will update.
            Binding resultFeaturesBinding = new Binding("LastResult");
            resultFeaturesBinding.Source = findTask;
            QueryDetailsDataGrid.SetBinding(DataGrid.ItemsSourceProperty, resultFeaturesBinding);
            findParameters.SearchText = FindText.Text;
            findTask.ExecuteAsync(findParameters);
            // Since binding to DataGrid, handling the ExecuteComplete event is not necessary.
        void findTask_ExecuteCompleted(object sender, FindEventArgs e)
            if (e.FindResults.Count > 0)
                foreach (FindResult result in e.FindResults)
                    result.Feature.Symbol = LayoutRoot.Resources["Sample"] as ESRI.ArcGIS.Client.Symbols.Symbol;
                    graphicsLayer.Graphics.Add(result.Feature);
            else
                MessageBox.Show("No features found");
JenniferNery
FindResult contain the following information: http://help.arcgis.com/en/webapi/silverlight/apiref/ESRI.ArcGIS.Client~ESRI.ArcGIS.Client.Tasks.Find...
You can use FindTask along with IdentifyTask to show more information about each feature. Please refer to the following SDK samples:
http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#Find
http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#Identify
