FeatureSet.ToJson() must now be called on the UI thread in 2.3
1496
12-20-2011 04:55 PM
RyanCooney
As of version 2.3 FeatureSet.ToJson() throws an exception if you call it from a background thread. This was not the case in 2.2. Was this an intended change?
System.InvalidOperationException: The calling thread cannot access this object because a different thread owns it.
   at System.Windows.DependencyObject.GetValue(DependencyProperty dp)
   at ESRI.ArcGIS.Client.Graphic.get_Layer()
   at ESRI.ArcGIS.Client.Tasks.Utils.JSON.ArcGISJsonWriter.GraphicsToFeatureServiceJson(IEnumerable`1 graphics, Boolean normalize, Boolean onlyDirty, List`1 fields)
   at ESRI.ArcGIS.Client.Tasks.FeatureSet.ToJson(Boolean includeGeometryInJson, Boolean normalize)
   at ESRI.ArcGIS.Client.Tasks.FeatureSet.ToJson()
dotMorten_esri
Esri Notable Contributor
Sorry, this wasn't intended and we'll have an update in a future release.
As a work-around for now, set the Fields property on the FeatureSet, prior to calling the worker thread, and you should be good to go.
Example:
FeatureSet fs = new FeatureSet()
 Fields = new List<Field>() //or FeatureLayer.LayerInfo.Fields
fs.Features.Add(new ESRI.ArcGIS.Client.Graphic() { Attributes = { { "ID", "1" } }, Geometry = new ESRI.ArcGIS.Client.Geometry.MapPoint(1, 2) });
System.ComponentModel.BackgroundWorker worker = new System.ComponentModel.BackgroundWorker();
worker.DoWork += (a, b) =>
  FeatureSet fs2 = (FeatureSet)b.Argument;
  b.Result = fs2.ToJson();
worker.RunWorkerCompleted += (a, b) =>
   MessageBox.Show(b.Result.ToString());
worker.RunWorkerAsync(fs);
Sorry for the inconvenience this might have caused you.
RyanCooney
Thanks for the quick reply. I've implemented the workaround and it does the trick.
--Ryan
