Problem with Map control inside of Telerik TileView
1190
12-20-2011 03:31 PM
TylerRothermund
When I use the Map control inside of a Telerik RadTileView it stops responding to mouse events.
I found this post on their site from 2 years ago where they say its a problem with ESRI map control
http://www.telerik.com/community/forums/silverlight/tileview/i-need-help.aspx
It sounds exactly like the problem that I've just run into.  Any Ideas???
DominiqueBroux
Esri Frequent Contributor
I never tested that Telerik control but somebody in this thread gave a workaround for a similar issue with the scrollviewer.
Hopefully this works in your case as well.
TylerRothermund
I see that there is a ScrollViewer in the heirachy that is wrapping the map, but none of the suggested solutions seem to fix the problem for me.
