Feature Attachment, can multiple features share the same attachment file?
2605
10-20-2011 08:22 AM
YongzhiYu
Hi All:
  I am in AGS 10, and I am implementing a project that need to attach some pdf files to multiple parcel features. Here is my quesion:
  Can multiple features share the same attachment file? In other word, can I attach one file to multiple features at one time?
An example is if I have one pdf file that I want to associate with 100 parcels, is there a way to attach the file to these 100 parcels at one time, so all the parcels reference the same attachment record in the parcel_ATTACH table? It just does not make sense if I have to attach the same file 100 times to each pacrel and create 100 records in the parcel_ATTACH table.
  In addition to my above question, can features from different feature class share the same attachment? I guess the answer would be no, since each feature class will have its own attachment table in the SDE database.
  Many thanks.
Yongzhi
JenniferNery
The REST API only supports add attachment at the feature level: http://sampleserver3.arcgisonline.com/ArcGIS/SDK/REST/fsaddattachment.html. You can call any of these AddAttachment method in code-behind: http://help.arcgis.com/en/webapi/silverlight/apiref/ESRI.ArcGIS.Client~ESRI.ArcGIS.Client.FeatureLay....
