customized maptip with buttons
1503
6
04-01-2011 09:03 AM
ThaoNguyen
I want to add some buttons to my graphic layer maptip.  I am able to do this, but the problem I have is I cannot move the mouse to the created buttons inside my MapTip because when I move my mouse toward buttons, the maptip disappears.  Is there a way for me to set the delay ?
I read another post mentioned about MapTipHideDelay, but can't find this property at all!
Thanks!
HeatherGonzago
Take a look at http://forums.esri.com/Thread.asp?c=158&f=2455&t=298745.
Morten talks about this a bit and states specifically that the maptips do not support "freezing".
ThaoNguyen
So, is there another way to do this?  I looked at InfoWindow, but it is for mouse click event and I want mouse over event.
ThaoNguyen
Ah, I just tried MouseEnter event for GraphicLayer and display InfoWindow.  It works.  However, I would like to see if there is a better option.  I just tried a quick test, other things I need to handle such as when to hide InfoWindow....
and there are other things I need to fix because it overwrites my drawing event :(, can't draw anymore.
ThaoNguyen
Will this be available in next release?  I think to have a tip delay time would be very useful.
DominiqueBroux
Esri Frequent Contributor
MapTipHideDelay is an attached property owned by the GraphicsLayer class and can be set to the maptip in order to define a hide delay.
There is a sample here : http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#GraphicsMapTip
the XAML code looks like:
          <esri:GraphicsLayer ID="StatesGraphicsLayer">
                <esri:GraphicsLayer.MapTip>
                    <Border esri:GraphicsLayer.MapTipHideDelay="00:00:01.5" CornerRadius="10" BorderBrush="#FF222957" BorderThickness="3" Margin="0,0,15,15"> .......
ThaoNguyen
Thank you!! That helps!
