Creating ClassBreaks for rendering graphics (polygons)
966
04-05-2011 09:30 AM
VincenzoPiscitelli
Given a set of values, how would one go about generating the appropriate classes to use in the ClassBreaksRenderer.
Details:
I first query a data source via a web service.  Using the results of the query I need to build a ClassBreaksRenderer and apply it to a dynamic layer with a where clause to restrict the polygons.  The same where clause was used to get the data in the first place.
Example:
Polygon     Population
CSD1        125,121
CSD2        49,125
CSD3        495,824
CSD4        120,458
CSD5        325,958
Ideally I would like ranges that would include all the data, with equal sized ranges.  In the real app, there may be hundreds of values.
Could this be done client-side?  And if so, how would one construct the ranges.
Any help would be appreciated.
DominiqueBroux
Esri Frequent Contributor
Did you look at this sample : http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#Thematic_Interactive ?
Seems close to what you need.
VincenzoPiscitelli
I don't know how I missed that sample.  I could have sworn that I examined each one.  Thanks for the info.  It is close to what I want and I can definitely expand on that sample.
Thanks again.
