Map WrapAround and ElementLayer
919
04-05-2011 08:31 PM
linusang
I'm testing the 2.2 API and found out that when I enable WrapAround and have a Video ElementLayer, the video doesn't "wraparound"?
Is this behavior by default?
Actually I've a InkCanvas ElementLayer which allows the user to make freeform drawings and scribble on the map... however when the wraparound is enabled the InkCanvas ElementLayer doesn't cover the wraparound region which posed a problem to me....
dotMorten_esri
Esri Notable Contributor
ElementLayer does not support WrapAround mode.
You should be able to use a GraphicsLayer for "ink" as well. Use the Draw class with the FreeHand mode.
Side note: please use the beta community forums for future questions on the beta products.
