Changing Toolbar Image in Code Behind
996
09-21-2010 06:46 AM
PaulHuppé
I am trying to change the image shown in the toolbar when the user selects a tool in the toolbar.  I tried to change the Source property of the image of the selected tool in the method "MyToolbar_ToolBarItemClicked" which is called when the user selects a tool.  When I click on a tool, I get the following message:
Microsoft JScript runtime error: Unhandled Error in Silverlight Application Object reference not set to an instance of an object.   at LacationMapViewer.MainPage.MyToolbar_ToolbarItemClicked(Object sender, SelectedToolbarItemArgs e)
   at ESRI.ArcGIS.Client.Toolkit.Toolbar.contentElement_MouseLeftButtonDown(Object sender, MouseButtonEventArgs e)
   at MS.Internal.CoreInvokeHandler.InvokeEventHandler(Int32 typeIndex, Delegate handlerDelegate, Object sender, Object args)
   at MS.Internal.JoltHelper.FireEvent(IntPtr unmanagedObj, IntPtr unmanagedObjArgs, Int32 argsTypeIndex, String eventName)
As anyone tried to do this?
Paul
JenniferNery
How are you setting the toolbar item's image?  I tried the following and it worked for me without exception.
var toolbarItem = MyToolbar.Items[e.Index];
var toolbarImage = toolbarItem.Content;
if (toolbarImage is Image)
  (toolbarImage as Image).Source = new System.Windows.Media.Imaging.BitmapImage(new System.Uri("/Assets/images/i_globe.png", System.UriKind.RelativeOrAbsolute));
PaulHuppé
That worked, thanks Jennifer.
