Attributes are not shown in editor class when i use add action
1720
12-11-2011 11:50 PM
SuleymanArslan1
I want to create a editing application and i am using silverlight api.
I am facing problem for some feature layers.
I am not able to update attributes after drawing geometry.
After drawing geometry on map, in EditCompleted event, attribute count return 0 on edit.Graphic.Attributes
Then i compare feature services which is working fine and which is not working.
Only difference i sow, it is not working if feature layer participating relationship class.
Is there a way to solve this problem,
        private void InitializeFeatureEditor()
            featureEditor = this.Resources["FeatureEditor"] as Editor;
            featureEditor.Map = this.MapControl;
            featureEditor.LayerIDs = this.featureLayerIDs.ToArray();
            featureEditor.AutoSelect = widgetConfig.AutoSelect;
            featureEditor.ContinuousMode = widgetConfig.ContinuousAction;
            featureEditor.GeometryServiceUrl = widgetConfig.geometryService.RESTURL;
            featureEditor.EditCompleted += new EventHandler<Editor.EditEventArgs>(FeatureEditor_EditCompleted);
            ButtonSaveEdits.Visibility = (widgetConfig.AutoSave) ? Visibility.Collapsed : Visibility.Visible;
            ButtonAddFreehandPolygon.Visibility = (widgetConfig.UseFreehand) ? Visibility.Visible : Visibility.Collapsed;
            ButtonAddFreehandPolyline.Visibility = (widgetConfig.UseFreehand) ? Visibility.Visible : Visibility.Collapsed;
        private void FeatureEditor_EditCompleted(object sender, Editor.EditEventArgs e)
            if (e.Action == Editor.EditAction.Add)
                Editor.Change edit = e.Edits.FirstOrDefault<Editor.Change>();
                if (!widgetConfig.AutoSave) featureEditor.Save.Execute(null);
                if (edit != null)
                    FeatureLayer fLayer = edit.Layer as FeatureLayer;
                    OpenFeatureDataEditor(fLayer, edit.Graphic);
JenniferNery
Graphic.Attributes is dependent on FeatureLayer.OutFields. Be sure to set FeatureLayer.OutFields.
SuleymanArslan1
I already set outfields. Actually this feature class participating geometric network. Is there any limitation for editing geometric network.
Following error shown in log.
type='ERROR' code='100005' target='' methodName='GraphicFeatureServer.ApplyEdits' machine='' user='?' process='10860' thread='5552' elapsed='30.26327'>Method failed.HRESULT = 0x8004040f : This is a FACILITY_ITF error that is specific to the interface that returned this error. See the documentation of the interface that returned this error for information about this HRESULT.
DominiqueBroux
Esri Frequent Contributor
The limitations that I know for editing geometric network are:
  • the data must be versionned (see doc)
  • there is no support at the client side to manage the topology. The topology will be updated by the geodatabase at the server side (e.g. after moving a node, you will not see immediatly the impact on the connected edges, but that will be OK after saving and refreshing your data).
That being said for your issue, sorry, I have no clue:(
