Accessing FeatureLayers from within code (ie FeatureLayer not defined in XAML)
1166
07-15-2010 08:53 AM
MichaelBlom
how would i write code to access and itterate the FeatureLayers of a service with only having the ArcGISDynamicMapServiceLayer defined in the XAML ie. without declaring the FeatureLayer in the XAML?
Below is how i am getting access to my LayerInfo's:
private void HawaiiPointsInitialised(object sender, EventArgs e)
            var dynamicService = sender as ArcGISDynamicMapServiceLayer;
                foreach (LayerInfo fl in dynamicService.Layers)
Mike
MichaelBlom
So, i think you need to define the feature layer within the XAML...
I tried to declare a feature layer in xaml then set the url in the code behind but you can't do that.
And i tried to create the FeatureLayer from scratch in the code behind, but no luck either.
Mike
DominiqueBroux
Esri Frequent Contributor
It's possible to create feature layers by code.
Something like:
privatevoid HawaiiPointsInitialised(object sender, EventArgs e)
var dynamicService = sender asArcGISDynamicMapServiceLayer;
if (fl.DefaultVisibility == false)
continue;
if(fl.SubLayerIds != null && fl.SubLayerIds.Length > 0) // group layer
continue;
FeatureLayer featureLayer = newFeatureLayer();
featureLayer.Url = dynamicService.Url + "/" + fl.ID.ToString();
featureLayer.ID = fl.Name;
myMap.Layers.Add(featureLayer);
