WebMap object move_to_basemap() method will not move the layer to the basemap
2184
12-20-2023 08:38 AM
Clubdebambos
MVP Regular Contributor
ArcGIS API for Python version 2.2.0.1
I have used the move_from_basemap() to move basemap to a layer.
from arcgis.gis import GIS
from arcgis.mapping import WebMap
## Access AGOL
agol = GIS("home")
## get webmap item
wm_item = agol.content.get("WM_ITEM_ID")
## create WebMap object
webmap = WebMap(wm_item)
## get basemap definition
basemap_lyr = webmap.definition["baseMap"]["baseMapLayers"][0]
## call move_from_basemap
webmap.move_from_basemap(basemap_lyr)
## update basemap
webmap.update()
This works perfectly! Now going in the other direction with move_to_basemap()
## Access AGOL
agol = GIS("home")
## get webmap item
## get layer definition
basemap_lyr = [lyr for lyr in webmap.layers if lyr.title == "Dark Gray Base"][0]
## move to basemap
webmap.move_to_basemap(basemap_lyr)
## update webmap
webmap.update()
I am returned this error..
arcgis.gis.Error: This layer type cannot be added as a basemap. See method description to know what layer types can be moved to basemap.
The layer is a VectorTileLayer and as per documentation should work!! I mean, its a layer that I switched from the basemap in the first place.
      "id": "dark-gray-base-layer",
      "opacity": 1,
      "title": "Dark Gray Base",
      "visibility": true,
      "layerType": "VectorTileLayer",
      "styleUrl": "https://www.arcgis.com/sharing/rest/content/items/5e9b3685f4c24d8781073dd928ebda50/resources/styles/root.json"
~ learn.finaldraftmapping.com
EarlMedina
I think this one can be logged as a bug. The reference list is:
        layer_types = [
            "ArcGISTiledMapServiceLayer",
            "ArcGISImageServiceLayer",
            "ArcGISImageServiceVectorLayer",
            "ArcGISMapServiceLayer",
            "ArcGISTiledImageServiceLayer",
            "ArcGISVectorTileLayer",
But the layerType attribute is set to "VectorTileLayer." From a quick glance at the source, it looks like "ArcGISVectorTileLayer" is only defined in arcgis/mapping/_types.py so I think the types are either incorrect or the logic needs to be updated to properly map to the types.
Clubdebambos
Thanks @EarlMedina
Have you got a link to the process for reporting as a bug?
Clubdebambos
Here's a workaround for now...
## Access AGOL
agol = GIS("home")
## WebMap Item ID
wm_item_id = "WM_ITEM_ID"
## get the webmap item as an item object
wm_item = agol.content.get(wm_item_id)
## create a WebMap object from webmap item
## Get the layer of interest
## Convert lyr definition to a dictionary
basemap_lyr_dict = dict(basemap_lyr)
## Remove the basemap layer from the Map
webmap.remove_layer(basemap_lyr)
## This needs to be called to make the remove layer stick
status = webmap.update()
print(status)
## Re-get the updated webmap item
## Get the webmap item data
item_data = wm_item.get_data()
## Update the Basemap list with the dictionary
item_data["baseMap"]["baseMapLayers"].append(basemap_lyr_dict)
## Define the webmap item properties
wm_item_properties = {"text":item_data}
## Update the webmap item properties
wm_item.update(item_properties=wm_item_properties)
NicholasGiner1
 Hello, thanks for sharing your question.  You can report bugs and make enhancement requests to the Python API public GitHub repo here: https://github.com/Esri/arcgis-python-api/issues
thanks,
Nick Giner - Product Manager
Clubdebambos
Reported as bug here: https://github.com/Esri/arcgis-python-api/issues/1739
