I'm trying to use the new Python-API with our on-premise system. Our company runs it's own public key infrastructure, so I've configured Portal for ArcGIS with a corresponding certificate. Furthermore, there is a company-wide proxy that we are using.
As a first throw, I'd like to connect to ArcGIS Online by doing this:
from arcgis.gis import GIS my_gis = GIS()
This crashes with:
c:\Program Files\ArcGIS\Pro\bin\Python>python.exe "C:\temp\Test.py"
File "c:\Program Files\ArcGIS\Pro\bin\Python\lib\urllib\request.py", line 1254
, in do_open
h.request(req.get_method(), req.selector, req.data, headers)
File "c:\Program Files\ArcGIS\Pro\bin\Python\lib\http\client.py", line 1106, i
n request
self._send_request(method, url, body, headers)
File "c:\Program Files\ArcGIS\Pro\bin\Python\lib\http\client.py", line 1151, i
n _send_request
self.endheaders(body)
File "c:\Program Files\ArcGIS\Pro\bin\Python\lib\http\client.py", line 1102, i
n endheaders
self._send_output(message_body)
File "c:\Program Files\ArcGIS\Pro\bin\Python\lib\http\client.py", line 934, in
_send_output
self.send(msg)
File "c:\Program Files\ArcGIS\Pro\bin\Python\lib\http\client.py", line 877, in
send
self.connect()
File "c:\Program Files\ArcGIS\Pro\bin\Python\lib\http\client.py", line 1252, i
n connect
super().connect()
File "c:\Program Files\ArcGIS\Pro\bin\Python\lib\http\client.py", line 853, in
connect
self._tunnel()
File "c:\Program Files\ArcGIS\Pro\bin\Python\lib\http\client.py", line 832, in
_tunnel
message.strip()))
OSError: Tunnel connection failed: 407 authenticationrequired
During handling of the above exception, another exception occurred:
File "C:\temp\Test.py", line 7, in <module>
my_gis = GIS()
File "c:\Program Files\ArcGIS\Pro\bin\Python\lib\site-packages\arcgis\gis.py",
line 95, in __init__
verify_cert=self._verify_cert, client_id=self._client_id)
File "c:\Program Files\ArcGIS\Pro\bin\Python\lib\site-packages\arcgis\_impl\po
rtalpy.py", line 160, in __init__
client_id=client_id)
File "c:\Program Files\ArcGIS\Pro\bin\Python\lib\site-packages\arcgis\_impl\co
nnection.py", line 281, in __init__
self.login(username, password, expiration, client_id)
nnection.py", line 504, in login
resp = self.post('', { 'f': 'json' }, add_token=False) # probe portal to fin
d auth scheme
nnection.py", line 1031, in post
resp = opener.open(url, data=encoded_postdata.encode())
File "c:\Program Files\ArcGIS\Pro\bin\Python\lib\urllib\request.py", line 466,
in open
response = self._open(req, data)
File "c:\Program Files\ArcGIS\Pro\bin\Python\lib\urllib\request.py", line 484,
in _open
'_open', req)
File "c:\Program Files\ArcGIS\Pro\bin\Python\lib\urllib\request.py", line 444,
in _call_chain
result = func(*args)
File "c:\Program Files\ArcGIS\Pro\bin\Python\lib\urllib\request.py", line 1297
, in https_open
context=self._context, check_hostname=self._check_hostname)
File "c:\Program Files\ArcGIS\Pro\bin\Python\lib\urllib\request.py", line 1256
, in do_open
raise URLError(err)
urllib.error.URLError: <urlopen error Tunnel connection failed: 407 authenticati
onrequired>Is it related to some proxy issues and if yes, where do I have to configure the proxy?
Rohit,
Does it support proxy authentication as well?
Thanks
Hi Rohit,
we also need proxy authentication!
Eric
Hi Eric, Anthony,
For secure proxies, can you try the following:
# username : password @ server gis = GIS(proxy_host="username:[email protected]", proxy_port=542)If it doesn't work, please let me know what kind of proxy server you are using.
Rohit
Hi Rohit,
this works fine - thanks.
Eric
Hi Rohit,
The above connection string is not working for me. Is there anything that can be done?
Thanks.
Richard.
Hi Rohit Singh and Tyler Burns,
It still doesn't work fine for me:
import csv,os, sys, datetime, base64
from getpass import getpass
# import urllib2
print('===================')
print('The script that is running: ' + __file__)
print('First you have to log in to Portal for ArcGIS')
# Log in
username = 'axc013o'
# username = 'domain\\axc013o'
# password = os.environ.get('USERPASS')
# password = getpass(prompt='Password: ', stream=None)
password = base64.b64decode('randomcharacters').decode('utf-8')
# proxy = urllib2.ProxyHandler({'http': 'http://proxyServer:8080', 'https': 'https://proxyServer:8080'})
# opener = urllib2.build_opener(proxy)
# urllib2.install_opener(opener)
portalURL = 'https://portalDomain/portal/'
# portalURL = 'https://portalHostname:7443/arcgis/home/'
myPortal = GIS(portalURL, username, password)
# myPortal = GIS(portalURL, username, password, proxy_host=f'{username}:{password}@proxyServer', proxy_port=8080)
# myPortal = GIS(portalURL, username, password, proxy_host=f'{username}:{password}@10.123.8.111', proxy_port=8080)
# verify_cert=False does not fix issue.
# another one of our proxy servers also doesn't work.
print ("Start: "+datetime.datetime.today().strftime('%c'))Traceback (most recent call last):
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\urllib\request.py", line 1318, in do_open
encode_chunked=req.has_header('Transfer-encoding'))
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\http\client.py", line 1254, in request
self._send_request(method, url, body, headers, encode_chunked)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\http\client.py", line 1300, in _send_request
self.endheaders(body, encode_chunked=encode_chunked)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\http\client.py", line 1249, in endheaders
self._send_output(message_body, encode_chunked=encode_chunked)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\http\client.py", line 1036, in _send_output
self.send(msg)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\http\client.py", line 974, in send
self.connect()
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\http\client.py", line 1407, in connect
super().connect()
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\http\client.py", line 950, in connect
self._tunnel()
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\http\client.py", line 929, in _tunnel
message.strip()))
OSError: Tunnel connection failed: 503 Service Unavailable
File "C:\Users\AXC013O\Downloads\z\getUsers.py", line 29, in <module>
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\gis\__init__.py", line 325, in __init__
raise e
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\gis\__init__.py", line 310, in __init__
referer=self._referer)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\_impl\portalpy.py", line 163, in __init__
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\_impl\connection.py", line 308, in __init__
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\_impl\connection.py", line 554, in login
resp = self.post('', { 'f': 'json' }, add_token=False) # probe portal to find auth scheme
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\_impl\connection.py", line 1131, in post
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\urllib\request.py", line 526, in open
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\urllib\request.py", line 544, in _open
'_open', req)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\urllib\request.py", line 504, in _call_chain
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\urllib\request.py", line 1361, in https_open
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\urllib\request.py", line 1320, in do_open
raise URLError(err)
urllib.error.URLError: <urlopen error Tunnel connection failed: 503 Service Unavailable>I even tried putting the proxy server in my environment variables, as well as turning off the pac server, as shown in the attached png.
Can you please suggest any tips?
Does this support a PAC based proxy?
We do not currently support PAC-based proxies in the Python API. Neither the standard library nor requests (which Python API will use for web requests) support these out of the box, so the API would have to be designed specifically to handle the information the PAC file provides.
There is a package called pypac (https://github.com/carsonyl/pypac) that does this functionality, but we do not currently have the infrastructure to build this for designing and testing at this time.
I am at v 1.7.1, and I see that now proxies are available as kwargs for sure!
arcgis.gis module — arcgis 1.7.1 documentation
I am using arcgis.__version__ = 1.8.5 and the error I am getting is
gis = arcgis.gis.GIS(PORTAL_URL, USER, PASSWORD,
proxy_host="10.10.10.210", proxy_port=8080)
When I use the code in a jupyter notebook I get a very long stack trace with basically the same error.
~\AppData\Local\ESRI\conda\envs\arcgis_tools\lib\ssl.py in _create(cls, sock, server_side, do_handshake_on_connect, suppress_ragged_eofs, server_hostname, context, session)
826 if context.check_hostname and not server_hostname: -->
827 raise ValueError("check_hostname requires server_hostname")
828 ValueError: check_hostname requires server_hostname During handling of the above exception, another exception occurred:
