Upgrade arcgis module to version 1.6.0
2059
5
03-20-2019 06:33 AM
TomGeo
Starting to look at the Python SDK I was wondering how to upgrade to the latest version of the SDK. I am running version 2.3.1 of ArcGIS Pro which comes with version 1.5.1 of the arcgis module. Following the guide I can clone the arcgispro-py3 environment, but that's where the guide is a bit outdated, since version 2.3.1 of ArcGIS Pro does not come with a button 'New' giving the opportunity to name the environment self, but only with a button to browse environments or to clone the default.
Once I clone the default environment I can upgrade the environment using
conda upgrade -c esri arcgis
However, the module arcgis will be upgraded to version 1.5.3 and I would have rather expected the version to be 1.6.0.
I was wondering how I can upgrade to 1.6.0.
In addition, when the cloned environment is set as the active environment, running jupyter notebook opens the browser on http://localhost:8888/tree, where there is only a white page. Using one of the urls provided in the command line after running notebooks only leads to the same outcome.
So in the end I cannot even run 1.5.3...
Any chance someone here can tell me where it goes south?
- We are living in the 21st century.
GIS moved on and nobody needs a format consisting out of at least three files! No, nobody needs shapefiles, not even for the sake of an exchange format. Folks, use GeoPackage to exchange data with other GIS!
DanPatterson_Retired
it is pinned (check for your pinned file
conda upgrade -c esri --no-pin arcgis
KarstenRank
It works! Thanks Dan
Greetings Karsten
TomGeo
Thanks a lot Dan!
DavidColey
MVP Frequent Contributor
Hi Dan - do you know why the pinning occurs and/or where to go to check the 'pinned' file?
just do a file explorer search in your ArcGIS pro installation path, looking for a file called 'pinned' with no file extension.  It is a text file, so notepad or notepad++… just don't mess with it unless you have a backup saved in a safe place... like where you saved your download of the *.exe for Pro and/or the msi and cab file derived from it
