Update Cloned EXB App
153
a month ago
Labels (3)
CS_IBM
Greetings,
I can clone A EXB webapp to B EXB webapp.
A EXB ID is 0fbeb86981414ce6b1eced19cf4f6c4a
B EXB ID is 0fbeb86981414ce6b1eced19cf4f6c4ab
When A EXB is updated is it possible to update B EXB, keeping the ID?
So when B EXB is updated it keeps the ID = 0fbeb86981414ce6b1eced19cf4f6c4ab
Clone A version 2 >> B version 2
B version 2 ID = '0fbeb86981414ce6b1eced19cf4f6c4ab'
Regards,
Clive
JakeSkinner
Esri Esteemed Contributor
Hi @CS_IBM,
You won't be able to keep the same IDs, but you can use these tools to copy Experience Builder apps between different Portals (i.e. staging portal --> prod portal).  If the app already exists in the target portal, it will update the app.
