I am learning Python through ArcGIS Notebooks. In the lesson:
https://www.arcgis.com/home/item.html?id=5aee4d0f252941e1ae421b78a8ccbe60
https://learngis1.maps.arcgis.com/home/item.html?id=2eda03cbeec64e89a924cd9f9a1fad4b
my_first_map.save(webmap_properties)
traffic_map.save(webmap_properties)
gives an error
--------------------------------------------------------------------------- KeyError Traceback (most recent call last) <ipython-input-9-6aee56bfc856> in <module> ----> 1 traffic_map.save(webmap_properties) /opt/conda/lib/python3.7/site-packages/arcgis/widgets/_mapview/_mapview.py in save(self, item_properties, mode, thumbnail, metadata, owner, folder) 1513 metadata = metadata, 1514 owner = owner, -> 1515 folder = folder) 1516 elif mode == "3D" or "webscene" in mode.lower(): 1517 return self._save_as_webscene(item_properties, /opt/conda/lib/python3.7/site-packages/arcgis/widgets/_mapview/_mapview.py in _save_as_webmap(self, item_properties, thumbnail, metadata, owner, folder) 1537 self._update_webmap_layers_from_js() 1538 item = self.webmap.save(item_properties, thumbnail, -> 1539 metadata, owner, folder) 1540 self.webmap.item = item 1541 return item /opt/conda/lib/python3.7/site-packages/arcgis/mapping/_types.py in save(self, item_properties, thumbnail, metadata, owner, folder) 827 828 item_properties['type'] = 'Web Map' --> 829 item_properties['extent'] = self._process_extent(item_properties.get('extent', None)) 830 item_properties['text'] = json.dumps(self._webmapdict, default=_date_handler) 831 if 'typeKeywords' not in item_properties: /opt/conda/lib/python3.7/site-packages/arcgis/mapping/_types.py in _process_extent(self, extent) 711 712 #process and return the result --> 713 if self._contains_nans(result): 714 return "" 715 else: /opt/conda/lib/python3.7/site-packages/arcgis/mapping/_types.py in _contains_nans(self, result) 729 """a bool of if projection output `result` contains any NaNs""" 730 for value in result: --> 731 if "nan" in str(value['x']).lower(): 732 return True 733 if "nan" in str(value['y']).lower(): /opt/conda/lib/python3.7/site-packages/arcgis/geometry/_types.py in __getitem__(self, k) 181 182 def __getitem__(self, k): --> 183 return dict.__getitem__(self, k) 184 185 KeyError: 'x'
Sharing your full code would be beneficial.
from arcgis.gis import GIS
gis = GIS("home")
# Item Added From Toolbar
# Title: Traffic Collisions | Type: Feature Service | Owner: Learn_ArcGIS
traffic = gis.content.get("79d3e458dcaf486f81c5591a67538179")
traffic
# Title: Pasadena Block Groups | Type: Feature Service | Owner: Learn_ArcGIS
block_groups = gis.content.get("af363700f8f84c11a02f084e78a296aa")
block_groups
traffic_map=gis.map('Pasadena, California')
traffic_map.add_layer(block_groups)
traffic_map.add_layer(traffic)
webmap_properties = {'title':'Pasadena_Traffic_NB_SB','snippet':'Pasadena Traffic map from a notebook,',
'tags':['ArcGIS Notebooks', 'Pasadena','traffic']}
1514 owner = owner,
1541 return item
827
711
714 return ""
715 else:
732 return True
181
184
185
KeyError: 'x'
@SB9 Just an update. I was able to resolve this by clicking the "restart the kernel, re-run the whole notebook" button at the top
Thanks MichelleMarasco. That works. I'm unsure why restarting the kernel is necessary, but it solved the problem.
