unable to save webmap from notebook
3522
6
05-01-2021 09:56 AM
SB9
I am learning Python through ArcGIS Notebooks. In the lesson:
https://www.arcgis.com/home/item.html?id=5aee4d0f252941e1ae421b78a8ccbe60
https://learngis1.maps.arcgis.com/home/item.html?id=2eda03cbeec64e89a924cd9f9a1fad4b
my_first_map.save(webmap_properties)
traffic_map.save(webmap_properties)
 gives an error
KeyError                                  Traceback (most recent call last)
<ipython-input-9-6aee56bfc856> in <module>
----> 1 traffic_map.save(webmap_properties)
/opt/conda/lib/python3.7/site-packages/arcgis/widgets/_mapview/_mapview.py in save(self, item_properties, mode, thumbnail, metadata, owner, folder)
   1513                                         metadata = metadata,
   1514                                         owner = owner,
-> 1515                                         folder = folder)   1516         elif mode == "3D" or "webscene" in mode.lower():
   1517             return self._save_as_webscene(item_properties,
/opt/conda/lib/python3.7/site-packages/arcgis/widgets/_mapview/_mapview.py in _save_as_webmap(self, item_properties, thumbnail, metadata, owner, folder)
   1537         self._update_webmap_layers_from_js()
   1538         item = self.webmap.save(item_properties, thumbnail,
-> 1539                                 metadata, owner, folder)   1540         self.webmap.item = item
   1541         return item
/opt/conda/lib/python3.7/site-packages/arcgis/mapping/_types.py in save(self, item_properties, thumbnail, metadata, owner, folder)
    827
    828         item_properties['type'] = 'Web Map'
--> 829         item_properties['extent'] = self._process_extent(item_properties.get('extent', None))
    830         item_properties['text'] = json.dumps(self._webmapdict, default=_date_handler)
    831         if 'typeKeywords' not in item_properties:
/opt/conda/lib/python3.7/site-packages/arcgis/mapping/_types.py in _process_extent(self, extent)
    711
    712                         #process and return the result
--> 713                         if self._contains_nans(result):
    714                             return ""
    715                         else:
/opt/conda/lib/python3.7/site-packages/arcgis/mapping/_types.py in _contains_nans(self, result)
    729         """a bool of if projection output `result` contains any NaNs"""
    730         for value in result:
--> 731             if "nan" in str(value['x']).lower():
    732                 return True
    733             if "nan" in str(value['y']).lower():
/opt/conda/lib/python3.7/site-packages/arcgis/geometry/_types.py in __getitem__(self, k)
    181
    182     def __getitem__(self, k):
--> 183         return dict.__getitem__(self, k)
    184
    185
KeyError: 'x'
DavidPike
MVP Notable Contributor
Sharing your full code would be beneficial.
SB9
from arcgis.gis import GIS
gis = GIS("home")
# Item Added From Toolbar
# Title: Traffic Collisions | Type: Feature Service | Owner: Learn_ArcGIS
traffic = gis.content.get("79d3e458dcaf486f81c5591a67538179")
traffic
# Title: Pasadena Block Groups | Type: Feature Service | Owner: Learn_ArcGIS
block_groups = gis.content.get("af363700f8f84c11a02f084e78a296aa")
block_groups
traffic_map=gis.map('Pasadena, California')
traffic_map.add_layer(block_groups)
traffic_map.add_layer(traffic)
webmap_properties = {'title':'Pasadena_Traffic_NB_SB','snippet':'Pasadena Traffic map from a notebook,',
'tags':['ArcGIS Notebooks', 'Pasadena','traffic']}
1514 owner = owner,
1541 return item
827
711
714 return ""
715 else:
732 return True
181
184
185
KeyError: 'x'
MichelleMarasco
I am having the exact same issue. Super frustrating.
@SB9  Did you ever resolve this?
MichelleMarasco
@SB9 Just an update. I was able to resolve this by clicking the "restart the kernel, re-run the whole notebook" button at the top
tchaulla
Worked for me too!
DanHuerter2
Thanks MichelleMarasco.  That works.  I'm unsure why restarting the kernel is necessary, but it solved the problem.
