Unable to clone layer
1102
06-06-2023 12:24 PM
Labels (2)
ZacharyKasson
-Goal: I am trying to create a script to access a layer on portal and clone it. After cloning it I would like to overwrite a layer in either a SQL database or back in portal.
-Reason: As the original layer updates I would like to run the script to update the copy in which I have view layers created from.
-What I have tried: I have tried a multitude of things, but have not found a way to clone the layer without hitting a type error or a way to save the layer in a SQL DB or portal.
-Here is some code and errors for creating a clone:
source_layer = gis.content.search(source_layer_name, item_type="Feature Layer")[0]
temporary_copy = ContentManager.clone_items(source_layer)
File "<string>", line 1, in <module>
TypeError: clone_items() missing 1 required positional argument: 'items'
temporary_copy = ContentManager.clone_items(items=source_layer)
TypeError: clone_items() missing 1 required positional argument: 'self'
-For saving the layer I have really only tried publish(), but it doesn't seem to take a layer as an input.
How do you save a layer in portal? in a SQL DB? using arcgis api for python?
-Here is what the entire script I have been working with:
def overwrite_existing_layer(source_layer_name, sql_database, layer_name):
    try:
        # Connect to the ArcGIS Portal
        gis = GIS('pro')
        portal_dstore = gis.datastore
        # Retrieve the feature layer you want to clone
        # Create a temporary copy of the layer or use clone_item() shown above
        temporary_copy = source_layer.layers[0].query()
        # Save the temporary copy to overwrite the existing layer in the SQL database
        temporary_copy.publish()
        print("Temporary copy overwritten in SQL database.")
        # Delete the temporary copy
        # portal_dstore.delete_layers(temporary_copy)
        # if not temporary_copy.exists:
        #     print("Temporary copy deleted.")
        print('Finished running script')
    except Exception as e:
        # Handle any errors that occur during the process
        print(f"An error occurred: {str(e)}")
-Any and all advice is appreciated. I'm pretty new to using python within the ArcGIS suite. I have not found the esri documentation very useful so if there is any other recommended resources, those would be appreciated!
Tags (1)
