Start Stop Services Errors
5386
11
10-17-2023 07:42 AM
kapalczynski
I am having issues with getting a list of Services PRIOR to stopping and starting them.  I am trying to get this info two different ways and getting errors on both...
One of the examples is coming from here:
https://support.esri.com/en-us/knowledge-base/how-to-stop-gis-services-using-arcgis-api-for-python-0...
Any ideas what I am doing wrong?
    from arcgis.gis import GIS
    import arcgis.gis.admin
    nonProdPortal = "https://xxxx.xxx.gov/portal"
    loginName = "xxxxx"
    loginPass = "xxxxx"
    gis = GIS(nonProdPortal, loginName, loginPass, verify_cert=False)
    gis_servers = gis.admin.servers.list()
    #To stop specific service(s)
    for server in gis_servers:
        for service in server.services.list():
            #print(service.properties.serviceName)
            if service.properties.serviceName == "TMPD_AGO":
                #service.stop()
                print("Stopping TMPD_AGO")
ERROR:
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\gis\server\_common\_base.py", line 93, in __getattr__
"'%s' object has no attribute '%s'" % (type(self).__name__, name)
AttributeError: 'Server' object has no attribute 'services'
    from arcgis import gis
    nonProdPortal = "https://xxxxx.gov/portal"
    loginName = "xxxx"
    loginPass = "xxxx"
    mygis = gis.GIS(nonProdPortal, username=loginName, password=loginPass, verify_cert=False)
    #mygis = GIS(nonProdPortal, loginName, loginPass, verify_cert=False)
    servers = mygis.admin.servers.list()
    one_server = servers[0]
    services_on_that_server = one_server.services.list()
    one_of_those_services = services_on_that_server[0]
    # provided your service is running to begin with
    print(one_of_those_services.status)
ERROR:
kapalczynski
I got it... leaving some junk in here that is commented out that still does stuff...
BUT basically I can point to a Stand Alone Server and:
  • List Folder Names
  • List Services in those folder names
  • specific a specific folder and turn on and off services in that folder...
It would be nice to read into that LIST OBject and get the specific service name and use that to start and stop services... Where I could say IF the service name = XXX stop it and leave the others in the folder alone...
I have not figure out how to do that yet... as a list object is being sent back to me.
EDIT: While I was posting @EarlMedina  posted the solution to get the name... I UPDATED the code below to print that out but did not build the IF THEN yet...
THANKS @EarlMedina
import arcgis.gis.server
def listServices():
    nonProdPortal = "https://xxx.xxxx.xxx.gov/portal"
    loginName = "xxxx"
    loginPass = "xxxx"
    print(gis_servers)
    print("")
    server1 = gis_servers[0]
    print(server1)
    print("")
    foldersList = server1.services.folders
    print(foldersList)
    # LIST FOLDERS and THEN ALL THE SERVICES IN THOSE FOLDERS
    #for folder in foldersList:
    #    foldername = folder
    #    print(foldername)
    #    servicesList = server1.services.list(folder=foldername)
    #    for servicename in servicesList:
    #        servicenameValue = servicename
    #        print("---" + str(servicenameValue))
    servicesList2 = server1.services.list(folder='DEQ_DEV')
    for service in servicesList2:
        # GIVE ME THE SERVICE NAME
        service_name = service.iteminformation.properties["name"]
        print(service_name)
        print(service)
        status = service.status
        print(status)
        #service.stop()
        #service.start()
        print(status)
if __name__ == '__main__':
    listServices()
EarlMedina
Is the account you are logging in with an administrator account?
kapalczynski
If you see my last post... I got a list of servers and say one had http and one https .. I changed my code to point the second index and it works fine... but this is pointing to a hosted server and I want my non prod portal server.  Its using the same credentials...
I dont think this is a system admin but its got elevated permissions.
The error does not seem to be permissions... its telling me that the http server that services is not in the server object...
But then it runs on the hosted server fine.
kapalczynski
OK Weird thing.... I printed my servers and noticed that the main server does not have HTTPS and the hosted server does have HTTPS
I changed my code to point the the hosted Feature Server because that has HTTPS in the name...and the code runs...
Changed the index to point to the second server:  server1 = gis_servers[1]
Is that the reason or does this code only run on a Hosted Server?
    print(gis_servers)
    print("")
    print(server1)
    validate = gis.admin.servers.validate()
    print("Is the server valid? " + str(validate))
    print(foldersList)
    print("")
    print("-----------")
    print("")
    servicesList = server1.services.list()
    print(servicesList)
Results:
[<Server at http://xxx.xxxxx.gov/env/admin>, <Server at https://xxxx.xxxx.gov/hosting/admin>]
<Server at https://xxxxx.xxxxx.gov/hosting/admin>
Is the server valid? True
['Hosted', 'System', 'Utilities', '/']
[<Service at https://xxxl.xx.xxxx.gov/hosting/admin/services/bmpReportTool.GPServer>,
<Service at https://xxxl.xx.xxxx.gov/hosting/admin/services/ImportCurveData.GPServer>,
<Service at https://xxxl.xx.xxxx.gov/hosting/admin/services/npdesReportTool.GPServer>,
<Service at https://xxxl.xx.xxxx.gov/hosting/admin/services/SWPPP_Annual_Dev.MapServer>,
<Service at https://xxxl.xx.xxxx.gov/hosting/admin/services/SWPPP_Monthly_Dev.MapServer>]
EarlMedina
For standalone servers, you want to be using the  arcgis.gis.server module instead of arcgis.gis.admin. Update your code to use the correct module and it should work for the standalone servers.
kapalczynski
Tells me Server not defined
I updated my IMPORT to arcgis.gis.server
def listServices():
    loginName = "xxxx"
    loginPass = "xxxxx"
    server_base_url = "https://xxxxx.gov/portal/admin/"
    gis_server = Server(url=f"{server_base_url}/web_adaptor/admin",
                        token_url=f"{server_base_url}/web_adaptor/tokens/generateToken",
                        username=loginName,
                        password=loginPass)
    foldersList = gis_server.services.folders
    print(foldersList)
kapalczynski
OK I think I made progress...
So the serviceList2 returns a list object? but I am just looking for the Service Name... how do I get that?
Returned:
<Service at https://xxx.cov.xxx.gov:6443/arcgis/admin/services/DEQ_DEV/VDEQ_Petro_Release_DEV.MapServer>
Looking for
def listServices():
    nonProdPortal = "https://xxx.gov/portal"
    loginName = "xxx"
    loginPass = "xxxxx"
    print(server1)
    servicesList2 = server1.services.list(folder='DEQ_DEV')[0]
    print(servicesList2)
EarlMedina
The name you can find in the service iteminformation:
kapalczynski
Hey @EarlMedina  do I mark your replay above regarding import arcgis.gis.server module as the solution and leave my full working code below as a reply?  Want to make sure you get credit for this as you steered me in the correct direction ????
EarlMedina
Oh, it doesn't matter. Whatever is most useful to anyone out there. I'm just here to help out.
