Stand Alone API for Python
1154
07-15-2021 07:49 AM
SolomonBacon313
I am looking to install API for Python 1.9 on a disconnected environment but still support all functions. Specifically the append functions. Is there any way to get pre release or the API as stand alone?
DanPatterson
MVP Esteemed Contributor
It is available on anaconda
Arcgis :: Anaconda.org
... sort of retired...
SolomonBacon313
Is this option an "Air Gap" solution?
DanPatterson
You can also install arcpy from the same site if you need it.  The only requirement to using arcpy is that the local machine must have a valid license to use ArcGIS Pro installed.  So you can create separate conda environments and just install the arcgis and/or the arcpy modules
