Should Item.usage() work on Portal 10.7?
1229
05-07-2019 11:39 AM
BarryBiediger
I had expectations (not unsubstantiated) that I could use item.usage() after upgrading to 10.7. Note the following from the api docs:
However, when I try to run it on an item in portal, I get "Error generating usage report."  It works fine on AGOL.  I'm starting to suspect it's not really implemented yet.
simoxu
by MVP Alum
MVP Alum
Apparently... When I tried, I got an error:
ValueError: Usage() only supported for ArcGIS Online items.
