Set popup in a layer published by code
1942
07-11-2024 07:19 AM
mody_buchbinder
I am using standard code (from the examples) with arcpy and python api to publish a layer (by ref) with feature access.
When I load the mapImage into empty webmap the popup (identify) is turned off by default.
I need to turn it on to see the popups.
If I load the same mapImage to Pro  I do see identify without any extra setting.
When I use Pro (without code) to publish a web layer the problem does not exists. The layer have popups on by default.
I found a few examples about how you turn popup on in a WebMap (using get_data) but no example of how to do it for mapImage or feature service.
I can not find any different between the service that was published using code and the one I created in Pro without code.
Anybody know how to set the default popup to "on" in code for service (not WebMap)?
JakeSkinner
Esri Esteemed Contributor
Hi @mody_buchbinder,
Can you provide the code you are using to publish the service?  Also, is this occurring in Portal or ArcGIS Online?
mody_buchbinder
The code I use is very similar to the solution here:  https://community.esri.com/t5/python-questions/publish-a-referenced-feature-service-from-arcgis/td-p...
It can be found in many versions in the Pro docs.
I am publishing to a local Portal.
Thanks
mody_buchbinder
I did some more testing. I published the same layer from Pro and code.
Then in notebook I have these lines:
from arcgis.gis import GIS
gis = GIS("pro")
idCode = "2f4b3fd237ae44b9af774adbbafa482f"
idPro = "47e920caec774f53a27a59217de07028"
serverCode = gis.content.get(idCode)
serverPro = gis.content.get(idPro)
serverPro.get_data(try_json=True)
#serverCode.get_data(try_json=True)
So this return a json the represent the layer, it has popupElements tag in it.
When I uncomment the last line and try to get the data from the item published by code I get empty json.
I do not see any set_data method (incase I will create the json myself.
Any idea?
mody_buchbinder
I found the solution
There is a way to save the properties into the target service
import json
serverData = serverPro.get_data(try_json=True)
item_properties = {"text": json.dumps(serverData)}
serverCode.update(item_properties=item_properties)
Now I have to build this json (since I cannot get it from a service published from Pro) but this is simple task
