ServicesDirectory is mind bogglingly slow
772
06-10-2022 09:56 AM
Brian_Wilson
Honored Contributor
Yesterday it was running fine in Jupyter Notebook, took 15 seconds. Today it's up to 4 minutes so far.
From this post https://community.esri.com/t5/arcgis-api-for-python-questions/folders-key-error-on-servicesdirectory...
it looks like the call was put in there only for internal use and I should not call it?? If true, I wonder if you could add that to the docs, Esri??
from arcgis.gis.server.catalog import ServicesDirectory
sd = ServicesDirectory(url="https://xxxxx/server",username="user",password="pass")
sd.list()
If I call sd.list(folder="My Folder") then it works like a charm.
Brian_Wilson
Honored Contributor
For anyone searching for how to use ServicesDirectory, don't, it does not work correctly. Use something like this, it's fast and it works.
from arcgis.gis import GIS
print(arcgis.__version__)
gis = GIS(url="https://xxx/portal",username="xxx",password="xxx")
myservers=gis.admin.servers.list()
services = myservers[0].services.list()
for s in services:
  print(s.iteminformation.properties)
Brian_Wilson
Honored Contributor
for s in services:
