How to calculate area for each feature in a Spatially Enabled Dataframe?
2545
5
06-10-2022 10:35 AM
Josh-R
How does one calculate area for each feature in a Spatially Enabled Dataframe?  I read it in from a shapefile and need the acreage of each feature. I also would like to store the area as a new column.  This should be simple but I can't find a straight forward answer that works, I've referenced the two similar posts. Thank you!
sedf = pd.DataFrame.spatial.from_featureclass(myShapeFile)
jcarlson
You want to get a GeoSeriesAccessor and use its area property, maybe pipe that into a new field.
gsa = arcgis.features.GeoSeriesAccessor(sedf['SHAPE'])
# add column using insert
sedf.insert(0, 'the_area', gsa.area, True)
# alternatively, just add a new column at the end of the sedf
sedf['the_area'] = gsa.area
- Josh Carlson
Kendall County GIS
DanPatterson
MVP Esteemed Contributor
you could just calculate in the shapefile first
... sort of retired...
Josh-R
Please excuse the simplified example. I'm doing a bunch geoprocessing beforehand that I'm not showing, so I would like an updated calculation. I can do it in arcpy no problem but I am curious if the arcgis api has a way to do it.
jcarlson
- Josh Carlson
Kendall County GIS
Josh-R
Exactly what I was looking for! Thank you!
DavidAnderson_1701
