Publish SD to specific Server folder and to specific item id
1433
07-17-2023 05:53 AM
SimonSchütte_ct
MVP Regular Contributor
I´d like to publish a referenced service using an existing SD to ArcGIS Enterprise.
I found two different methods:
- publishing to Portal, which allows to set the item_id, but not the ArcGIS Server Folder:
publish(publish_parameters=Noneaddress_fields=Noneoutput_type=Noneoverwrite=Falsefile_type=Nonebuild_initial_cache=Falseitem_id=Nonegeocode_service=None)
arcgis.gis module | ArcGIS API for Python
- using the Service Manager publish_sd(sd_file, folder=None, service_config=None) arcgis.gis.server module | ArcGIS API for Python, I can publish the SD to a specific Server Folder, but I don´t see an option to define the Portal item id.
How can I define both?
CSDING_GIS
I would also like some better documentation on these methods.
Also dropping this link to a related topic Publish_parameters aren't used when publishing .sd... - Esri Community
