Prepare_data ERROR
1459
02-28-2020 09:51 PM
MoahmmedAl_Sulaimani
Hello every one, I'm trying to follow the example of extracting building foot print, same steps here, but with my own dataset
arcgis-python-api/Extracting Building Footprints From Drone Data.ipynb at f1183261b6cea0a3d98bbe462c...
I'm getting the below ERROR, any help
I'm using the Notebook inside ArcGIS Pro 2.5
and successfully installed the Deep Learning dependencies as per instructions
ERROR
and same ERROR I got by using the Train Tool inside ArcGIS Pro 2.5
Tags (1)
by Anonymous User
Not applicable
Hi your pillow is broken, use this command to uninstall pillow
conda remove pillow --force
then reinstall using the following command
conda install -c esri pillow
add --no-pin if you are using arcgis pro python environment
