Merge FGDB Feature Class with AGOL Hosted Feature Layer
1430
08-12-2021 01:30 PM
JaredPilbeam2
I'm trying to overwrite a hosted feature layer using a FGDB Feature Class. I've tried a couple things. First, I've tried merging the two.
import arcgis
from arcgis.gis import GIS
gis = GIS('Home')
fl = gis.content.get('item id goes here')
layer_to_merge = r'C:\Users\jpilbeam\Default.gdb\firstdose_test'
arcgis.features.analysis.merge_layers(fl, layer_to_merge)
 Result:
Exception: Job failed.
2 Using this post as an example, I tried overwriting the hosted feature layer.
import os, sys, arcpy
source = GIS('Home', verify_cert=False)
layer = source.content.get('itemID goes here')
layer.update({}, r'C:\Users\jpilbeam\Default.gdb\firstdose_test')
layer.publish(overwrite=True, file_type='fileGeodatabase')
 Result:
Exception: Invalid JSON in 'text' parameter.
(Error Code: 400)
PeterMilenkovic
I have done this in the past with great success.
I used the feature layer collection manager class
from arcgis.features import FeatureLayerCollection
item =  gis.content('itemid')
FLC = FeatureLayerCollection.fromitem(item)
FLC.manager.overwrite('Your file')
https://developers.arcgis.com/python/api-reference/arcgis.features.managers.html#arcgis.features.man...
File/table/layer /field names have to match.
Hope this helps
