Map Tile Package Publishing Fail
4668
10
08-30-2017 07:19 PM
JingjingLi
I've tried using the following script to upload a map tile package and publish it to a hosted tile layer but it failed. The map tile package was successfully uploaded and the hosted tile layer was successfully created. However, it didn't copy the min and max scale to the service so the publishing tile process was failed.
That's the script I used.
from arcgis.gis import GIS
gis = GIS("https://www.arcgis.com", "username", "password")
cm = gis.content
print(gis._con._token)
itemProperties = {}
data = r"TileMapPackage\PlanningTeamArea_agspro.tpk"
item = cm.add(itemProperties, data=data, folder="test_automation")
if item != None:
    print(item)
    tiledServiceItem = item.publish()
    if tiledServiceItem != None:
        print("published")
that's the error message I got.
  File "D:/Data/Requests/Requests 2017/26_0511_AGOL_Automation_Test/Codes/addingItems.py", line 11, in <module>
  File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\gis\__init__.py", line 4299, in publish
    serviceitem_id = self._check_publish_status(ret, folder)
  File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\gis\__init__.py", line 4519, in _check_publish_status
    raise Exception("No job id")
Exception: No job id
Any idea?
DanPatterson_Retired
is itemProperties supposed to be an empty dictionary? ie { } or a list? [ ]
JingjingLi
As far as I know. It is a dictionary. And according to this sample, I don't see what's wrong with my script.
Apparently it is missing a jobId (whatever that is.)
You can find out more details by examining the script
C:\ArcPro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\gis\__init__.py
the def in question is
    def _check_publish_status(self, ret, folder):
its help says...
Internal method to check the status of a publishing job.
        :param ret: Dictionary representing the result of a publish REST call. This dict should contain the
                    `serviceItemId` and `jobId` of the publishing job
        :param folder: obtained from self.ownerFolder
and it failed to pass on line 4485 returning the error message on 4519... raise Exception("No job id")
So if you know what a job id is...
JingjingLi
Yep. The job id is supposed to be generated by arcgisonline but I don't see it anywhere.
JingjingLi
And I tested the same script using version 1.0.1 and it worked. I am currently running 1.2.1.
JingjingLi
    "services": [{
            "type": "Map Service",
            "serviceurl": "https://tiles.arcgis.com/tiles/okWBWNlpfMx5q1bT/arcgis/rest/services/PlanningTeamArea_agspro/MapServ...",
            "size": 926219,
            "serviceItemId": "dc7ee927d0e242bc8de5200634532de1",
            "encodedServiceURL": "https://tiles.arcgis.com/tiles/okWBWNlpfMx5q1bT/arcgis/rest/services/PlanningTeamArea_agspro/MapServ..."
that's the response from the publish service url, and obviously there is no jobId in it.
Since no one who does this has chimed in, I would contact tech support or search Esri Support Home to see if any other reports along the same line have appeared.
KevinEscalera2
Hi Dan, did you resolved this issue?, I'm having the same problem using the publish function of an scene layer package item in ArcGIS Online....
by Anonymous User
Not applicable
Kevin, did you find a solution on this front?
Trying to overwrite an existing hosted feature layer; the service definition creates and overwrites the sd on AGOL, but I can't get the script to actually use the updated SD to overwrite the feature layer.
