Joined View Layer
2288
04-05-2024 05:28 AM
gargarcia
Is it possible to use the python Api to create a joined view layer? I have checked the reference guide and saw the join analysis tool, but it didn't appear to have a parameter for output type like using the tool in the classic map viewer has. I also see the function for creating a view, but nothing associated about joins. If it is not possible with the python Api are there alternative methods to programmatically create joined view layers?
EarlMedina
You can accomplish this, but it requires a bit of setup and understanding of how things work. Let me give you an example.
Suppose I want to join Feature Layer A to Table B. I know the field I want to join on is named "Activity," and I want to perform a Left Join.
Begin with necessary imports, initial setup:
from arcgis.gis import GIS
from arcgis.features import FeatureLayer, Table, FeatureLayerCollection
gis = GIS("https://www.arcgis.com", username="hari", password="seldon")
fl_url = "https://services3.arcgis.com/xxxxxxxxxxx/arcgis/rest/services/pntLayer/FeatureServer/0"
tbl_url = "https://services3.arcgis.com/xxxxxxxxxxx/arcgis/rest/services/TableToJoin/FeatureServer/0"
fl = FeatureLayer(fl_url, gis)
tbl = Table(tbl_url, gis)
Next, you'll want to add an index on the join field to both services:
index_to_add = {"indexes":[
        "name": "Activity_Index",
        "fields": "Activity",
        "isUnique": False,
        "isAscending": True,
        "description": "Activity_Index"
fl.manager.add_to_definition(index_to_add)
tbl.manager.add_to_definition(index_to_add)
Create a blank view service, initialize a FeatureLayerCollection from the result for later use:
view_service = gis.content.create_service(name="joined_view", is_view=True)
view_flc = FeatureLayerCollection.fromitem(view_service )
Now, you need to think about which fields you want from the source feature layer and source table:
sourceFeatureLayerFields = [
        "name": "Activity",
        "alias": "Activity",
        "source": "Activity"
        "name": "Description",
        "alias": "Description",
        "source": "Description"
        "name": "StartDate",
        "alias": "StartDate",
        "source": "StartDate"
        "name": "EndDate",
        "alias": "EndDate",
        "source": "EndDate"
sourceTableFields = [
        "name": "Note",
        "alias": "Note",
        "source": "Note"
This is where the magic happens. We use some of the info above to create a definition we can use to end up with our desired joined view:
field_to_join_on = "Activity"
view_lyr_name = "sampleJoinedView"
definition_to_add = {
  "layers": [
      "name": view_lyr_name,
      "displayField": "",
      "description": "AttributeJoin",
      "adminLayerInfo": {
        "viewLayerDefinition": {
          "table": {
            "name": "sampleJoinedView",
            "sourceServiceName": fl.properties.name,
            "sourceLayerId": 0,
            "sourceLayerFields": sourceFeatureLayerFields,
            "relatedTables": [
                "name": "testjoin",
                "sourceServiceName": tbl.properties.name,
                "sourceLayerId": 0,
                "sourceLayerFields": sourceTableFields,
                "type": "LEFT",
                "parentKeyFields": [
                  field_to_join_on
                "keyFields": [
                  field_to_join_on
                "topFilter": {
                  "groupByFields": field_to_join_on,
                  "orderByFields": "OBJECTID ASC",
                  "topCount": 1
            "materialized": False
        "geometryField": {
          "name": f"{view_lyr_name}.Shape"
view_flc.manager.add_to_definition(definition_to_add)
Put it all together and we have:
        "isUnique": False,
        "name": "Activity",
        "name": "EndDate",
        "alias": "EndDate",
        "source": "EndDate"
        "name": "Note",
        "alias": "Note",
        "source": "Note"
  "layers": [
      "displayField": "",
      "adminLayerInfo": {
          "table": {
            "sourceLayerId": 0,
            "relatedTables": [
                "name": "testjoin",
                "sourceLayerId": 0,
                "type": "LEFT",
                  field_to_join_on
                "keyFields": [
                  field_to_join_on
                "topFilter": {
                  "topCount": 1
        "geometryField": {
There are other options you can play around with in the view layer definition, but this should give you a good starting point. To get a better idea of what your definition needs to look like, you could use the UI to create the exact view you want and capture the network traffic right after you click the button to create the joined view. The call you need to pay most attention to is "addToDefinition".
Hope this helps you and a lot of other people.
EarlMedina
        "isUnique": False,
        "name": "Activity",
        "name": "EndDate",
        "alias": "EndDate",
        "source": "EndDate"
        "name": "Note",
        "alias": "Note",
        "source": "Note"
  "layers": [
      "displayField": "",
      "adminLayerInfo": {
          "table": {
            "sourceLayerId": 0,
            "relatedTables": [
                "name": "testjoin",
                "sourceLayerId": 0,
                "type": "LEFT",
                  field_to_join_on
                "keyFields": [
                  field_to_join_on
                "topFilter": {
                  "topCount": 1
        "geometryField": {
        "isUnique": False,
        "name": "Activity",
        "name": "EndDate",
        "alias": "EndDate",
        "source": "EndDate"
        "name": "Note",
        "alias": "Note",
        "source": "Note"
  "layers": [
      "displayField": "",
      "adminLayerInfo": {
          "table": {
            "sourceLayerId": 0,
            "relatedTables": [
                "name": "testjoin",
                "sourceLayerId": 0,
                "type": "LEFT",
                  field_to_join_on
                "keyFields": [
                  field_to_join_on
                "topFilter": {
                  "topCount": 1
        "geometryField": {
gargarcia
Thank you for the detailed answer. I will give this a try!
mikaël
Thanks for a detailed post!
For anybody wondering, if you want to create a table instead of a feature layer, just remove the "geometryField" key in the "adminLayerInfo" dict.
I played around trying to change "table" to "layer" or "feature layer" in the "viewLayerDefinition" dict also, but that just results in an error.
You can also reuse all the fields in your sources.
fl_fields = []
tbl_fields = []
for f in fl.properties.fields:
    fl_fields.append(dict(f))
for f in tbl.properties.fields:
    tbl_fields.append(dict(f))
 and then put fl_fields in "sourceLayerFields" for your "table" and tbl_fields in "sourceLayerFields" for your "relatedTables".
