I'm looking at using ArcGIS Python API in an AWS Lambda function. I have installed all of the minimum dependencies based on Install and Setup | ArcGIS API for Python but some of these dependencies seem to be an overkill when used in AWS. Would the kerberos & ntlm packages actually be required and probably the same with oauthlib?
At the moment, I leaning towards ujson, six & requests are probably the bare minimum for AWS Lambda.
It would be great to find out the actual bare minimum per scenario (eg. If server/portal using local win accounts then only ujson, six & requests are required, etc)
Thanks for any help with this.
I've run into the Lambda deployment size limitation in the past, so I understand your predicament. What functionality do you need from the Python API? On at least one occasion, it was easier to just write a custom class for my Lambdas that handled the essentials. I was doing simple stuff like querying a service to generate a report.
Earl,
The use case I'm looking at this for CI/CD pipeline. Storing artifacts in S3 bucket (eg. sd files, mapx files, json for web maps) and then invoking lambda via a schedule to take these artifacts from S3 and publish them into ArcGIS Enterprise.
I'm thinking of building a docker file and using it that way instead now.
At the moment, I'm getting an error in loading the packages 'asn1' cannot be found for the crypto package
HI - if I can re-open this thread -
My use case is, to pull a latitude/longitude from a MapServiceLayer Docs :
from arcgis.mapping import MapServiceLayer
map_service_layer = MapServiceLayer(url='...../GISViewer/MapServer/57')
feature_set=map_service_layer.query(where='', text=text)
featureset.to_json
this seems like a fairly small-sized package, but I am currently forced to load a Docker image when I run this lambda; any suggestions on fitting the software for MapServiceLayer into a lambda layer would be by me appreciated.
Thank you!
RKatz,
You don't need the arcgis python api to do this.
Using the requests module and send a GET request to your url (eg. url='...../GISViewer/MapServer/57/query?f=json&token=.....) will return json data
