ImportError: PyCapsule_Import could not import module "datetime"
8931
15
12-04-2023 11:49 AM
Rob24
Hello, I have been running some scripts for a while without issue.  Even after upgrading to ArcGis 3.1.1
Now, started receiving this error at random times in the code:
(this error shows it occurred in CopyFeatures, sometimes it happens during other functions)
Fatal Python error: InitDatetime: Could not import datetime C API
Python runtime state: initialized
Current thread 0x000025ac (most recent call first):
File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\geoprocessing\_base.py", line 512 in <lambda>
File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\management.py", line 4690 in CopyFeatures
installed:
Conda version is 4.1.4
Base Python on machine is 3.11
PyCharm 2021.1.3 (Community Edition)
Build #PC-211.7628.24, built on June 29, 2021
Runtime version: 11.0.11+9-b1341.60 amd64
VM: OpenJDK 64-Bit Server VM by JetBrains s.r.o.
Windows 10 10.0
GC: G1 Young Generation, G1 Old Generation
Memory: 2048M
Cores: 16
Tried the following:
1. uninstalled:
   ArcGIS Pro
   Pycharm
   Python
2. removed any lingering folders for:
   ArcGIS Pro
   pip cache
3. re-installed all 3 (from 1)
Been working with ArcGis for about a year now, still learning.   Any guidance on this would be appreciated.
DanPatterson
MVP Esteemed Contributor
Tech Support would be your best option if you removed all python, pycharm and Pro installations.
There is little use in installing 3.1.1 if you are having problems
Pro 3.2 uses 3.9.18
Good luck
... sort of retired...
DanPatterson
arctoolbox functions like CopyFeatures would be expecting arcpy based on python 3.9.18, your base
...Base Python on machine is 3.11...
if you are working in different python versions, are you switching back to an arcpy/arcgis happy environment first?
Rob24
Hi Dan,   Thank you for the response,
I currently only work with the ArcGIS Python so the interpreter is set to Conda environment pointing to the arcgispro-py3 env.
DanPatterson
came from your error message, do you have other python versions installed?
Rob24
Hi Dan,
I only have python 3.11
DanPatterson
you have arcgis pro installed, hence you should have python 3.9,18 installed as well
arcpy is built against 3.9.18
Rob24
Dan,   I can uninstall python 3.11 and go grab 3.9.18 .
I'm wondering if this explains why sometimes it would actually run fine and other times just error out (erratic behavior) .
DanPatterson
That would be useful and I would recommend a complete reinstall of Pro if you use it mostly
Don't be worried about the title, the procedure is what is important
Problem: ArcGIS pro Freezes on the Initializing Screen before the Sign in Dialog Box Displ (esri.com...
Rob24
Thank you Dan!,  I will try this route and report back.
Rob24
Update:  still having the same issue.  I installed ArcGIS 3.1.1 (without installing Python separately).  and the error keeps coming back to CopyFeatures.
in the pycharm terminal:
python --version
Python 3.9.16
I know you mentioned arcpy was built against 3.9.18 so I don't know if this is now the issue.
still do not understand why these same scripts where working for months and without changes or updates and started getting this error.
either way, thank you for the help @DanPatterson I appreciate it!
