ImportError: PyCapsule_Import could not import module "datetime"
8805
15
12-04-2023 11:49 AM
Rob24
Hello, I have been running some scripts for a while without issue.  Even after upgrading to ArcGis 3.1.1
Now, started receiving this error at random times in the code:
(this error shows it occurred in CopyFeatures, sometimes it happens during other functions)
Fatal Python error: InitDatetime: Could not import datetime C API
Python runtime state: initialized
Current thread 0x000025ac (most recent call first):
File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\geoprocessing\_base.py", line 512 in <lambda>
File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\management.py", line 4690 in CopyFeatures
installed:
Conda version is 4.1.4
Base Python on machine is 3.11
PyCharm 2021.1.3 (Community Edition)
Build #PC-211.7628.24, built on June 29, 2021
Runtime version: 11.0.11+9-b1341.60 amd64
VM: OpenJDK 64-Bit Server VM by JetBrains s.r.o.
Windows 10 10.0
GC: G1 Young Generation, G1 Old Generation
Memory: 2048M
Cores: 16
Tried the following:
1. uninstalled:
   ArcGIS Pro
   Pycharm
   Python
2. removed any lingering folders for:
   ArcGIS Pro
   pip cache
3. re-installed all 3 (from 1)
Been working with ArcGis for about a year now, still learning.   Any guidance on this would be appreciated.
DanPatterson
MVP Esteemed Contributor
Tech Support would be your best option if you removed all python, pycharm and Pro installations.
There is little use in installing 3.1.1 if you are having problems
Pro 3.2 uses 3.9.18
Good luck
... sort of retired...
Rob24
Hi Dan, that is my next step, appreciate your time!
Luiz_RobertoArueira_da_Silva
Good morning!
I have a similar problem!
I created a script from the export of an ArcGis Pro model, using Python from ArcGis Pro 3.2 (Python 3.9.18 [MSC v.1931 64 bit (AMD64)] on win32), recently installed.
When executing the script, the message appears when executing the command: arcpy.conversion.ExportFeatures
If anyone has an idea on how to solve it....
Thanks!
DanPatterson
copy the script here so people can see what might be causing the issue
Code formatting ... the Community Version - Esri Community
Sorry, I don't have permission to share the code.
A part of the command that generates the error:
print ("select by location camada realizado")
# Process: Export Features (Export Features) (conversion)
Incidentes_filtrado = "in_memory\\Incidentes_filtrado"
arcpy.conversion.ExportFeatures(in_features=incidentes_Layer1, out_features=Incidentes_filtrado, field_mapping="uuid .....
login efetuado
select by attribute camada do realizado
Thanks foo your time!
DanPatterson
You will have to contact tech support.  There isn't enough information to decipher a possible cause with what is given
