I need to Mean for multiple rasters in a folder with their corresponding rasters in another folder
5095
8
11-21-2019 02:59 AM
ravitejaSETTIPALLI
I am attempting to iterate through and Mean two sets of corresponding rasters(each set conatains 136 files), named 'AQUA' (e.g. 'MOD04_3K.A2019060.mosaic.061.2019318071023.pssgmc_000501390776.Optical_Depth_Land_And_Ocean-Optical_Depth_Land_And_Ocean.tif') and 'TERRA' (e.g.'MYD04_3K.A2019060.mosaic.061.2019318064730.pssgmc_000501390767.Optical_Depth_Land_And_Ocean-Optical_Depth_Land_And_Ocean.tif'),but iam facing this Runtime error
Runtime error
File "<string>", line 7, in <module>
RuntimeError: ERROR 000732: Input Raster: Dataset D:\FINAL\TERRA\MYD04_3K.A2019060.mosaic.061.2019318064730.pssgmc_000501390767.Optical_Depth_Land_And_Ocean-Optical_Depth_Land_And_Ocean.tif.tif does not exist or is not supported
Lochlan Jones ‌@Dan Patterson
DanPatterson_Retired
could be the double *.tif.tif at the end of the filename
ravitejaSETTIPALLI
not working sir,please look into issue sir
ravitejaSETTIPALLI
ravitejaSETTIPALLI
ravitejaSETTIPALLI
sir could you trouble shoot my process,i attached the file and i have to
calculate mean for those corresponding data sets.
by Anonymous User
Not applicable
Hi Raviteja,
Does shortening the file names allow the code to work? Also, does removing the periods (".") in the file names help?
-Lauren
ravitejaSETTIPALLI
i tried as you said,but still facing same issueruntime error :
Runtime error
File "<string>", line 9, in <module>
RuntimeError: ERROR 000732: Input Raster: Dataset D:\final 2\TERRA\MYD04_3K.A2019060_terra.tif does not exist or is not supported
Your file names and paths need some work since they will continue to generate errors unless you raw encode them or use forward slashes
# ---- big fail
f = "D:\final 2\TERRA\Some.File.With.Periods.tif"
f
'D:\x0cinal 2\\TERRA\\Some.File.With.Periods.tif'  # ---- unicode fail
# ---- raw encoding with the little `r` works for sure
f = r"D:\final 2\TERRA\Some.File.With.Periods.tif"
f
'D:\\final 2\\TERRA\\Some.File.With.Periods.tif'
# ---- this works by chance because little f isn't the same as big F
f = "D:\Final 2\TERRA\Some.File.With.Periods.tif"
f
'D:\\Final 2\\TERRA\\Some.File.With.Periods.tif'
