How to report bugs in ArcGIS API for Python
199
a month ago
miro_aus
What is the best way to report bugs to help improve ArcGIS API for Python?
I am currently dealing with 2, using arcgis-api 2.4.1.1 ( conda 25.5.1, python 3.11.13, Windows 11)
Enabling optimised drawing times out with larger polygon layers
WARNING: Could not enable optimized drawing: Your request has timed out.
def set_optimized_drawing(published_item):
    try:
        logger.info("Enabling optimized drawing (multiScaleGeometry)")
        published_item.layers[0].manager.update_definition(
            {"multiScaleGeometryInfo": {"levels": []}}
    except Exception as e:
        logger.warning(f"Could not enable optimized drawing: {e}")
Rasters of the size around 52MB end up in infinite upload loop (consistently, tested many times), looking at network monitor it does the upload, goes stall for seconds, and tries again, and again... Publishing raster datasets using from arcgis.raster.analytics import copy_raster. Interestingly it works completely fine with smaller or larger rasters including 3 MB or 3GB.
def upload_raster(gis, temp_path, item_title, item_properties, item_folder_name):
    agol_folder = set_agol_folder(gis, item_folder_name)
    try:
        kwargs = {
            "input_raster": str(temp_path),
            "output_name": item_title,
            "gis": gis,
            "tiles_only": True,
        service_item = copy_raster(**kwargs)
        logger.info(
            "Raster uploaded, moving to designated folder and updating service properties..."
        service_item.move(agol_folder)
        service_item.update(item_properties=item_properties)
        return service_item
        logger.warning(f"Upload error: {e}")
        return None
DanPatterson
Beyond raising a ticket the standard Tech Support route, you could raise an "Issue" at their github site
Esri/arcgis-python-api: Documentation and samples for ArcGIS API for Python
... sort of retired...
DanPatterson
