How to query a specific layer from a Feature Service
2974
01-26-2022 08:07 AM
Aravinthkumar
Hello everyone,
I am trying to get the list of feature service which has a specific layer (for example WETTBEWERBER (the layer id is 0)) from a feature service,
from arcgis.gis import GIS
gis = GIS(url='https://url/portal', username='arcgis_python', password='amazing_arcgis_123')
layer_items = gis.content.search(query="WETTBEWERBER", item_type="Feature Layer")
for layer in layer_items:
    if "WETTBEWERBER" in layer.title.upper():
        print(f"Layer name: {layer.title}, \tOwner: {layer.owner}, \tLayer ID: {layer.id}")
 But no results are printed out, but the layer WETTBEWERBER is present in most of my feature services. What can be done in this case ??
I have tried to get the layers first using the following code to check whether I can get the layers using the API and I can get the layers.
layer_items = gis.content.search(query="5fg239sdsfs56sdfcs466s4f", item_type="Feature Service")
for item in self.api_query_result:
    layers = item.layers
for lyr in layers:
print(item)
try:
print(item.iditem.urllyr.properties["id"]lyr.properties["name"])
except Exception as e:
print(e)
I can get all the layers including the layer WETTBEWERBER (0) in it.
But I cannot list all the feature service which contains this particular layer, What am I doing wrong ??
Thank you for the insights.
jcarlson
layer.title.lower() would not match an all-caps string like "WETTBEWERBER". Did you mean "layer.title.upper()"?
- Josh Carlson
Kendall County GIS
Aravinthkumar
Yes, sorry for the typo here it is "layer.title.upper()" I have updated the post.
jcarlson
Looking at it again, a layer doesn't have a title property. The parent item has a title, but the layers have properties, in which you can find a name, as shown in the other code block you quoted.
To get the feature service itself, you have to reference the parent item. This snippet would return a list of all Feature Layers in your search:
items = gis.content.search('some string', item_type='Feature Service')
[a.url for b in items for a in b.layers]
 To filter this list, we can include a simple ternary operator in the same line.
[a for b in items for a in b.layers if a.properties['name'] == 'WETTBEWERBER']
I tested this on my own layers, and searching for the layer name "Records" across a bunch of layers yielded the following:
['https://maps.co.kendall.il.us/server/rest/services/Cadastral/Ordinance_Fabric/FeatureServer/1',
 'https://maps.co.kendall.il.us/server/rest/services/Hosted/ord_fabric_hosted/FeatureServer/0']
- Josh Carlson
Kendall County GIS
Aravinthkumar
Thank you for the detailed explanation, whether I should leave the query empty in the place of "some string" and kindly can you edit it with the exact syntax I cannot figure out from this, that will be really helpful.
