How to find which features in an SEDF cause .to_featureset() to fail?
1687
03-27-2024 06:29 AM
A_Schwab
I have a spatially enabled data frame with 20,000 features.
When I run `sedf.spatial.to_featureset()`, it fails with this error:
File "<stdin>", line 1, in <module>
File "C:\Users\User\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\lib\site-packages\arcgis\features\geo\_accessor.py", line 3680, in to_featureset
d = self.__feature_set__
File "C:\Users\User\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\lib\site-packages\arcgis\features\geo\_accessor.py", line 3339, in __feature_set__
geom_type = _geom_types[
KeyError: <class 'pandas.core.series.Series'>
When run the same command on random samples from the dataset, it works fine. E.g.
>>> sedf.sample(200).spatial.to_featureset()
<FeatureSet> 200 features
Is there any way to find out which feature(s) are causing the error with to_featureset(), to narrow down what the issue might be?
Tags (3)
A_Schwab
After some testing, the issue is in the first 30 features. to_featureset() works fine for all the rows after row 30:
>> sedf[30:20000].spatial.to_featureset()
<FeatureSet> 19970 features
Running to_featureset() on the first 30 rows still gives an error:
However, running the same command on subsets of the first 30 rows produces no error:
>>> sedf[0:10].spatial.to_featureset()
<FeatureSet> 10 features
>>> sedf[10:20].spatial.to_featureset()
>>> sedf[20:30].spatial.to_featureset()
I've exported the 30 records to CSV and looked through them, and can't see anything obvious that would cause them to trigger an error.
Anyone have any suggestions?
EarlMedina
Sorry, had to reread what you did and said earlier. I am curious what happens if you split the df into chunks. There are a number of ways to do this, but one fairly simple way to do this might be:
n = 10
df_list = [df[i:i+n] for i in range(0,len(df),n)] # Break up into groups of ten
for i, df in enumerate(df_list):
    start_idx = i * n
    print(f"Records {start_idx} through {start_idx + n - 1}")
I have seen that method fail because of illegal values, but never have I seen it behave in the manner you describe.
