How to draw a polygon or circle on few locations in Jupyter notebook?
3399
09-21-2018 03:54 AM
BhartenduThakur
In jupyter notebook, I'm trying to make draw a shape (say circle) on some location points plotted on map as shown below:
# df is a pandas dataframe with coloumns 'lon' & 'lat'
points = gis.content.import_data(df)
g.add_layer(points)
# cen_lon, cen_lat are center longitude and latitude respectively.
g.draw('circle',[cen_x, cen_y])
I want a circle/polygon should appear, which encircles the points of df upto some radius r
JoshuaBixby
MVP Esteemed Contributor
Since the data has already been loaded as a layer, what about arcgis.features.analysis.create_buffer?
BhartenduThakur
I tried the following (both with analysis.create_buffers and use_proximitiy.create_buffers (simo xu)]:
layer0 = g.layers[0]
buffer0 = use_proximity.create_buffers(layer0, distances=[50], units = 'Miles')
and getting this error:
AttributeError: 'NoneType' object has no attribute 'create_buffers'
simoxu
by MVP Alum
Agree with Joshua.
And here is an example using a quite similar approach, it should work straight away for your data if you give it some simple tweaks.
Proximity analysis | ArcGIS for Developers
