How to Access arcgis.gis.ItemDependency Properties
2359
01-10-2022 08:49 AM
PatrickMcKinney99
I read on the API reference that an Item has the property "dependencies," which "returns a class to manage the Item’s dependencies."  Does anyone know how to access/read the contents within the returned "arcgis.gis.ItemDependency" class?
I am assuming that the "dependencies" property of an item can inform me of what services are used in a web map.  I am working in the ArcGIS Online environment, so that "dependent_to()" and "dependent_upon()" methods are not relevant.
DanPatterson
MVP Esteemed Contributor
C:\your_install_folder\bin\Python\envs\arcgispro-py3\Lib\site-packages\arcgis\gis\__init__.py contains the definition and methods if you want to examine the code itself
... sort of retired...
ShaneHallowell
Did you ever get this figured out?
ChaseYoung323209
Were you ever able to figure this out? Im trying the write the dependencies to an html file but I cant access the class properties for some reason.
sam-gartrell
assuming you have an item instance, you can access the properties with `item.dependencies.properties`, or `ItemDependencies(item).properties`. It'll come back as `{"items: []}` if the item doesn't depend on anything.
