Get Users and Other info from AGOL User Store
4799
9
02-23-2023 05:12 AM
kapalczynski
I am trying to write a script that will get me the users, email, user name, User Type and Role
I can do the below but cant find the type for User Type and Role
Any thoughts on how to get their User Type and Role?
from arcgis.gis import GIS
import arcgis
import pandas as pd
agol_username = 'xyz'
agol_password = '\xyz'
output_csv = r'C:\Users\Desktop\projects\AGOL_Python\users.csv'
search_user = '*'
gis = GIS('https://xyz.maps.arcgis.com', agol_username, agol_password)
user_list = gis.users.search(query=search_user, max_users=2000)
output = []
for item in user_list:
    email = item.email
    username = item.username
    z = [email] + (username if isinstance(username, list) else [username])
    print(z)
    output.append(z)
print("")
print(output)
df = pd.DataFrame(output,columns=['name','email'], dtype=float)
print(df)
Kepa
by Esri Contributor
Digging into the API reference you can get the custom role ids this way:
roles = gis.users.roles.all()
Create a dictionary with role ids, which gives us ID:roleName key-value pairs:
rol_ids = {role.role_id: role.name for role in roles}
Finally, use the roleId property of user's object to get the name like this (I used an exception to catch default roles of the organization):
for user in users:
    try:
        print(user.username, rol_ids[user.roleId])
    except KeyError as e:
        print(user.username, e)
 Hope that helps!
Kepa
by Esri Contributor
You are in the right way, you just need to go further on the user object properties:
# Level 1 = Viewer , 2 = Creator, not sure about Editor & Mobile worker levels
item.level
item.role
item.userLicenseTypeId
Python API Reference (User)
kapalczynski
Thanks
I get this return ... where do I get a list of values for LEVEL?
RETURN:
['[email protected]', '[email protected]', '11', 'org_user', 'fieldWorkerUT']
How do I define 11?
What is org_user?
kapalczynski
Fir instance this is one return
['[email protected]', '[email protected]', '2', 'org_admin', 'creatorUT']
2 = Creator?
org_admin is not my role I see when I look this person up in AGOL
This person is a Creator and has a Custom Role of Publisher+
What is 'creatorUT'?
Kepa
by Esri Contributor
There are three possible values under role property:
org_userorg_publisher and org_admin
The only explanation for what you get is that custom roles are named as 'org_admin'.
Edit:
kapalczynski
Is there a way to query the user and get back their Role that is assigned via AGOL.
I query the users and get values that are not the same values as when you add a new Member.  This is VERY confusing.  If I am trying to add a user programmatically I see Mobile Worker in AGOL but:
  • when I query via python I see fieldWorkerUT.
  • They are a creator and when I query I get 2
I need to be able to bridge these terminologies so I can query and modify users programmatically.
For example when I query this person I get this:
BUT when I look at this users in AGOL I get this:
         MobileWorker and Data_Editor (which is a custom Role)
  1. I assume that fieldWorkerUT and Mobile Worker are the same thing?
  2. How to I query for the custom role that is set for this user?
  3. If I want to add a user programmitically do I say fieldWorkerUT or MobileWorker
  4. How would I refer to the custom role (Data_Editor vs org_user)
Kepa
by Esri Contributor
1. Yeah, I think so, but AGOL is always evolving so the exact name could change in the future
2. Answered below
3. and 4. When calling create method when adding users you can assign a custom role passing the specific role ID in the role parameter.
kapalczynski
If I use this admin tool I can read all the users
And it reads it correct... When Cant I do that via python
Kepa
by Esri Contributor
for user in users:
    try:
 Hope that helps!
kapalczynski
@Kepa  Thanks so much this is exactly what I was looking for.... I posted my script below incase anyone wants to reference....
I am writing this to a CSV file as well as displaying in a data frame
import arcgis
import pandas as pd
import csv
agol_username = 'xyzxyzx'
agol_password = 'xyzxyzx'
output_csv = r'C:\Users\Desktop\GIS_projects\AGOL_Python\users.csv'
search_user = '*'
gis = GIS('https://xyzx.maps.arcgis.com', agol_username, agol_password)
user_list = gis.users.search(query=search_user, max_users=5)
output = []
counter = 0
with open(output_csv, 'w', encoding='utf-8') as file:
     csvfile = csv.writer(file, delimiter=',', lineterminator='\n')
     csvfile.writerow(["username",                         # these are the headers; modify according to whatever properties you want in your report
                       "email",
                       "roleID",
                       "level",
                       "disabled",
                       "role",
                       "licenseType"
     for user in user_list:
        try:
            varusername = user.username
            varemail = user.email
            varRoleID = rol_ids[user.roleId]
            varlevel = user.level
            vardisabledValue = user.disabled
            varrole = user.role
            varlicenceType = user.userLicenseTypeId
            z = (varusername if isinstance(varusername, list) else [varusername]) + [varemail] + [varRoleID] + [varlevel] + [vardisabledValue] +  [varrole] + [varlicenceType]
            output.append(z)
            counter += 1
            csvfile.writerow([varusername,
                        varemail,
                        varRoleID,
                        varlevel,
                        vardisabledValue,
                        varrole,
                        varlicenceType
df = pd.DataFrame(output,columns=['name','email','RoleID','Level','disabled','role','licensetype'], dtype=float)
print(df)
