file = gis.content.add( >> Exception: Item type not valid.
1564
08-14-2024 03:40 AM
CS_IBM
Greetings,
I am trying to upload an EXB zipped file into AGOL based on an ESRI example for a shapefile. https://developers.arcgis.com/python/api-reference/arcgis.gis.toc.html?
The Item type is "type": "Experience Builder",
The code creates and Experience Builder App, then fails. The error message is:
File "C:\Upload_Access.py", line 24, in <module>
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\gis\_impl\_con\_connection.py", line 1023, in _handle_json_error
raise Exception(errormessage)
(Error Code: 400)
(Error Code: 400)
The code is:
countryside=r"C:\Temp\EXB.zip"
### Upload zipped EXB
item_properties = {
"title": "Upload Test",
"description": "Countryside",
"tags": "Access",
#data = WebExperience,
data = countryside,
I would appreciate assistance to resolve the issue.
Thanks
Clive
CodyPatterson
MVP Regular Contributor
Hey @CS_IBM
Instead of using "Experience Builder" as the type, could you try "Web Experience"?
From the documentation linked, it doesn't seem as there is an Experience Builder type, maybe Web Experience would do the trick!
Cody
CodyPatterson
Hey @CS_IBM
Cody
