Deploying function App to azure stuck on 'running pip install 2/4' when arcgis is in requirements.txt
4995
5
06-01-2024 11:01 PM
j-bromp
Hey guys,
I am having issues deploying a function app to Azure. I have restarted the whole process a few times, specified versions in requirements.txt, deployed a dummy function just to see if i could deploy. Dummy function deployed successfully, but when i add arcgis to requirements.txt it takes agggess and then fails. i tried putting my real code into the function and deploying without arcgis in the requirements.txt file (this fails pretty quickly), when i add arcgis to requirements.txt, the same thing happens - it takes agges on 'running pip install 2/4' then fails. I tried changing the deploy timeout to 1 hour in case it was just a size issue but it failed at about 45 minutes.
I get the message in vscode: "Deployment 'latest' not found."
Been trying to figure this out for a couple of days now to no avail. Any help would be much appreciated!
EarlMedina
Is there anything in the logs with more information about the failure? Is the .zip failing to upload, for example?
j-bromp
Hey @EarlMedina ,
This is in the output tab on vscode:
9:45:35 AM app-mapFilter: Zip package size: 8.18 kB
9:45:34 AM app-mapFilter: Fetching changes.
9:45:35 AM app-mapFilter: Cleaning up temp folders from previous zip deployments and extracting pushed zip file /tmp/zipdeploy/50ac60f2-0f7f-4715-846c-352384ae3e96.zip (0.01 MB) to /tmp/zipdeploy/extracted
9:45:37 AM app-mapFilter: Updating submodules.
9:45:38 AM app-mapFilter: Preparing deployment for commit id '0b64e5d8-9'.
9:45:38 AM app-mapFilter: PreDeployment: context.CleanOutputPath False
9:45:38 AM app-mapFilter: PreDeployment: context.OutputPath /home/site/wwwroot
9:45:38 AM app-mapFilter: Repository path is /tmp/zipdeploy/extracted
9:45:38 AM app-mapFilter: Running oryx build...
9:45:38 AM app-mapFilter: Command: oryx build /tmp/zipdeploy/extracted -o /home/site/wwwroot --platform python --platform-version 3.11 -p packagedir=.python_packages/lib/site-packages
9:45:39 AM app-mapFilter: Operation performed by Microsoft Oryx, https://github.com/Microsoft/Oryx
9:45:39 AM app-mapFilter: You can report issues at https://github.com/Microsoft/Oryx/issues
9:45:39 AM app-mapFilter: Oryx Version: 0.2.20230210.1, Commit: a49c8f6b8abbe95b4356552c4c884dea7fd0d86e, ReleaseTagName: 20230210.1
9:45:39 AM app-mapFilter: Build Operation ID: ba77e43aee976359
9:45:39 AM app-mapFilter: Repository Commit : 0b64e5d8-9c9f-4af9-815a-d303aca1c889
9:45:39 AM app-mapFilter: OS Type           : bullseye
9:45:39 AM app-mapFilter: Image Type        : githubactions
9:45:39 AM app-mapFilter: Detecting platforms...
9:45:43 AM app-mapFilter: Detected following platforms:
9:45:43 AM app-mapFilter:   python: 3.11.8
9:45:43 AM app-mapFilter: Version '3.11.8' of platform 'python' is not installed. Generating script to install it...
9:45:43 AM app-mapFilter: Source directory     : /tmp/zipdeploy/extracted
9:45:43 AM app-mapFilter: Destination directory: /home/site/wwwroot
9:45:43 AM app-mapFilter: Downloading and extracting 'python' version '3.11.8' to '/tmp/oryx/platforms/python/3.11.8'...
9:45:43 AM app-mapFilter: Detected image debian flavor: bullseye.
9:45:44 AM app-mapFilter: Downloaded in 1 sec(s).
9:45:44 AM app-mapFilter: Verifying checksum...
9:45:44 AM app-mapFilter: Extracting contents...
9:45:48 AM app-mapFilter: performing sha512 checksum for: python...
9:45:48 AM app-mapFilter: Done in 5 sec(s).
9:45:48 AM app-mapFilter: image detector file exists, platform is python..
9:45:48 AM app-mapFilter: OS detector file exists, OS is bullseye..
9:45:48 AM app-mapFilter: Python Version: /tmp/oryx/platforms/python/3.11.8/bin/python3.11
9:45:48 AM app-mapFilter: Creating directory for command manifest file if it does not exist
9:45:48 AM app-mapFilter: Removing existing manifest file
9:45:48 AM app-mapFilter: Running pip install...
checking the logs of the current function (dummy function) in vscode just says 'connected'.
Is there another place I can check logs?
Thanks for your reply!
EarlMedina
Not what I was expecting, but let's try something. What happens when you install the package with no dependencies? The format for that in requirements.txt is:
<package> --install-option="--no-deps"
j-bromp
@EarlMedina Still running into the same error unfortunately, stuck on 'running pip install (2/4) then fails.
requirements.txt file looks like:
azure-functions
requests
arcgis --install-option="--no-deps"
I found something online that suggested containerising the whole thing with docker so am going to try doing that and will update if i make any progress
RogerAsbury
Curious what route you eventually took on this. I have the same issue and we got around it by setting up a ci/cd pipeline in Github, which seems to work, but it's frustrating that workarounds have to be found for things like this. Particularly since it means I can't deploy directly from VS Code, which can be handy sometimes.
Roger Asbury
Analyst/Programmer - Fairbanks North Star Borough
